1992 TR512 transmission oil | FerrariChat
Discussion in 'Boxers/TR/M' started by dinos, Oct 7, 2019.
  1. dinos
    dinos Karting
    Jan 6, 2013
    106
    Athens - Greece
    Dinos
    Hello to all.
    Its time to change my transmission oil !
    The manual writes " AGIP SP FE LS SAE 75W/90"
    Shell advices "Spirax S5 ATE 75W-90"
    Agip ( ENI ) I found 2 recommendations:
    "ENI ROTRA LSX 75W-90" or "ENI Rotra MP 80w-90"
    Any ideas which oil is better from the 3 above ?
  2. Steve Magnusson
    25,115
    blkdiablo33 likes this.
  3. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,364
    my repair shop that i use put redline 75/90 ns and i additive i think was close to 10 qts
  4. dinos
    dinos Karting
    Jan 6, 2013
    106
    Athens - Greece
    Dinos
    Thank you for your reply.
    I checked for Ravenol and for the TR512 they recommend RAVENOL LS 75W-90.
  5. dinos
    dinos Karting
    Jan 6, 2013
    106
    Athens - Greece
    Dinos
    Thank you for you
    I will check if redline is available in my country !
  6. Steve Magnusson
    25,115
    #7 Steve Magnusson, Oct 9, 2019
    Yes, those LS specs seem OK (and does say good for transmissions), but more focused on the limited slip aspects rather than the transmission aspects. The data sheet on VSG seems a bit more expansive for the transmission issues and specifically mentions "better when cold". I haven't noticed any limited slip issues with the VSG, but please give a report back later if you try the LS. If I had some limited slip chatter noise when slow-speed turning with the VSG, the LS would be an option that I would consider.
    Not GL-5 so that's off my list for a TR/512TR (even though some pro F shops use it).
  7. ttforcefed
    ttforcefed F1 World Champ
    18,860
    if you want something that works MTL is way to go. maybe in texas you dont get the notchy second gear grind we get in the northeast cold
  8. Clyde Romero
    Clyde Romero Formula Junior
    Sep 6, 2019
    691
    Atlanta Georgia
    Clarence Romero
    I have over 109k on my 512 TR original tranny
    I use the Mobil one 80-90
    Never had any issues what so ever
