News
1990 T Dash fan control transistor
Discussion in 'Mondial' started by Aceofspades, Mar 18, 2020.
  1. Aceofspades
    Aceofspades Rookie
    Apr 24, 2019
    48
    Chicago
    Kevin K
  3. belfry
    belfry Karting
    May 14, 2015
    158
    Mine was inside the centre air vents. You'll need to remove the vents and you will see the part on a bracket which is attached with rivets.
  4. Aceofspades
    Aceofspades Rookie
    Apr 24, 2019
    48
    Chicago
    Kevin K
    Yea I been looking ever where still cant find
    Check out my photo
  5. stekkefun4
    stekkefun4 Formula 3
    2,209
    Belgium - Europe
    Well, it is located inside of the black box, that means you will have to open it up. It cannot be accessed through one of the holes on the sides or on top.
  6. Aceofspades
    Aceofspades Rookie
    Apr 24, 2019
    48
    Chicago
    Kevin K
  8. Rifledriver
    Rifledriver Two Time F1 World Champ
    27,086
    Austin TX
    Have you ever changed one?
  9. Rifledriver
    27,086
    Austin TX
    #7 Rifledriver, Mar 19, 2020
    Don't pull the dash. Reach inside and you'll feel it. I can see the wires in your picture.
    Find and follow the wires. It will lead you right to it.
  10. Aceofspades
    Aceofspades Rookie
    Apr 24, 2019
    48
    Chicago
    Kevin K
    These wires. I do have massive hands of a giant...
    Any hints would be great.
  11. stekkefun4
    2,209
    Belgium - Europe
    I had to remove this from a heating/cooling block that I already took out of the car and had to open the unit to remove it, there was no other access to it then to remove the black plastic bottom panel and reach for it. It was some work on the loose unit, about 8 screws had to be removed. I can image that it's a lot harder to do on a unit that's still behind the dashboard. I would recommend removing the entire dashboard (not that much work).
  13. belfry
    belfry Karting
    May 14, 2015
    158
    It's attached to the bottom inside edge
    I did not need to remove the dash.
