Hi All, This update shows the rebuild of the waterpump. These ferrari pumps are a nice piece of engineering. I'm really happy they can be rebuilt as with most modern items, they can't. Here are a few photos. Image Unavailable, Please Login Pump as removed from engine. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Some pretty bad deposits. Image Unavailable, Please Login Old and new parts. Image Unavailable, Please Login Image Unavailable, Please Login Nice clean housing. Image Unavailable, Please Login Image Unavailable, Please Login All back together with new seals, bearings and some Loctite for good measure. Image Unavailable, Please Login I'm quite pleased with how this turned out. So far we are at £12589.91 for parts and 91 hours for labour (other work was carried out, not all work from last update was on the waterpump). Thanks, Ian
Hi All, Apologies it has been a while but here is another update. This time, I'm refurbishing the intske plenum and CV joints. Enjoy. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login So far we are at £13799.99 for parts and 118 hours for labour. Thanks and speak soon, Ian
118 hours ,,,!! ha ha Not too bad,,, I have 16 years of labor into my 1981 Mondial. The labor is free
Hi All, Thanks for your comments, I am glad you are enjoying it. Next update. This update focuses on the reconditioning of the cylinder heads. The heads were in good condition except for one area, the inlet manifold runners to head join. I think what has happened is that the gasket began to fail and water began to leak into the inlet runners. Someone then possibly put a liquid gasket sealer into the coolant system to 'plug' the leak. This probably didn't stop the leak and hence, the car was taken off the road and the engine removed. The heads were sent to a machine shop to be cleaned and dressed. The exhaust valve guides were replaced with new ones as they were 'out of spec' but the inlet ones were still 'in spec'. I saw no reason to put excess or additional stress on the head replacing the inlet valve guides if they are 'in spec'. New valve stem oil seals were fitted all round. New solid stem valves were also installed all round. Finally, the valves springs and buckets were re-installed. Image Unavailable, Please Login Head gasket surface is in good condition. Image Unavailable, Please Login Camshaft bearing journals are in great condition. Image Unavailable, Please Login New exhaust valve guides installed. Image Unavailable, Please Login Image Unavailable, Please Login Inlet manifold runner to head connection surface cleaned up really well considering the state it was in after the inlet manifold runner was removed. Image Unavailable, Please Login New studs where required. Image Unavailable, Please Login Organisation speeds up reassembly. Image Unavailable, Please Login Valve collets going in. Image Unavailable, Please Login New and old valves. Image Unavailable, Please Login Head rebuild complete So, as an update £14528.99 for parts and 128 hours for labour. Thanks and speak soon, Ian
Hi All, Next post details the rebuild of the intake runners. They were soda blasted, mating faces machined and new rubbers and injectors installed. Enjoy! Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login So, as an update £14528.99 for parts and 133 hours for labour. Thanks and speak soon, Ian
@afterburner and @drinkseltzer thanks for the encouragement! There is light at the end of the tunnel!
Very nice work. I'm at the same point myself + complete restauration of the interiour and many more. Great to see these cars get the appreciation they deserve. With regards Jurgen, Belgium
Hi All, Next update for you. This time around I was working on making brake hoses, getting new keys made and installing a new clutch. The rubber hoses that are available on the market are about £35 each and last maybe a couple of years. With this in mind, I decided to raid my racing toolbox and make stainless lines. These come in at about £25 each and last much mcuh longer...and don't expand so give quite a good pedal feel. When I got the car, it had no keys, so to rectify this, I took out the ignition barrel and door locks and had new keys cut. Now I can fire up the electrics in preparation for the long awaited start. To finish, I insalled a new cluctch kit (friction plate, pressure plate, throw out bearing and re-ground flyweel). I then put on the bell housing with the obligatory loctite. Enjoy the pics. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login So far Im at £14,772.57 for parts and 139 hours of labour. Chat soon, Ian
Hi All, Next update, this centres on the installation of the camshafts and the cyclinder heads. Everything seemed to go together well. New copper gaskets were used and supplied by a company called 'E Dobson & Co.'. I had these specially comissioned so if anyone wants info on them, feel free to get in contact. Enjoy, Ian Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login So far Im at £15,572.58 for parts and 179 hours of labour. Chat soon, Ian
Hi All, It has been a while since the last update but lots of progress has been made. Long story short, the engine is in the car and runs! Here are a few pics of what went into getting it ready. Image Unavailable, Please Login Checking valve clearances Image Unavailable, Please Login Image Unavailable, Please Login Before and after of refurbished radiator Image Unavailable, Please Login Custom made clutch hose Image Unavailable, Please Login Image Unavailable, Please Login Before and after of cleaning of the timing covers Image Unavailable, Please Login Rebuilding of brake master cylinder Image Unavailable, Please Login Engine installed and up an drunning. Video can be seen in m instagram page https://www.instagram.com/p/CR8vsCODCeO/ Image Unavailable, Please Login Image Unavailable, Please Login New wheels and tyres The car is now pretty much ready for paint excpet for a few items here and there, clutch master cylinder, a few hoses and various interior parts etc. So far £20,329.02 for parts and 243 hours for labour. Chat soon, Ian
Hi All, It has been a while since the last update but lots of work has been done. It has mainly been bodywork and the car is now off to the paintshop! The end is in sight! Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login So far we are at £2,4194.73 for parts and 315 hours for labour. Chat soon, Ian
Very nice work and project. You look to be a talented guy. This will be a very rewarding project for sure. Did you saw the one that sold for $66,000.00 US in bring a trailer yesterday ? It was a very nice exemple but I think the Mondials are now starting to be recognized for the nice little car they are. I owned one for a while and now thinking about another one. I love them. Will follow your project.
Nice project Ian! Not sure if you put the komma on the right place but do you mean £24,194.73 Or a figure around 2,500 GBP?
@JLF I'm glad you are liking it. @godabitibi thank you for the compliment, it is a rewarding project. I didn't see the Mondial on BAT but I'm pleased to see values rising. @MvT I wish I had the comma in the wrong place, unfortunately the total at the time of writing was £24,194.73 (more now!). @Turbo-man Netherlands Hello from Northern Ireland and I'm glad you are enjoying the restoration. @DHC I am glad you are liking the series, if you have any questions, please ask. Hi All, Long time no post! The car has been at the bodyshop for the last few months and good progress is being made. Below are some photos of what has been happening. Enjoy! Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login So far we are still at £24,194.73 for parts and 316 hours for labour. (only took an hour to take it to the body shop but the bodyshop cost is not included yet) Speak soon, Ian
