16" Mondial Tyres | FerrariChat
16" Mondial Tyres
Discussion in 'Mondial' started by Longstone Tyres, Jun 4, 2019.
  1. Longstone Tyres
    Longstone Tyres Formula 3
    Sponsor
    Feb 2, 2006
    1,812
    Dougal
    I am a big fan of the Michelin TRX tyres and without doubt thatt is what i would want fitted if I had a Mondial. However i have recently found a listing mentioning 16" wheels on Mondial.
    Pirelli have recently made some period P7 tyres in 16" https://www.longstonetyres.co.uk/pirelli-collezione/cinturato-p7.html i wondered if they might be of interest to you?
    Also if they did fit 16" i would like to update my page https://www.longstonetyres.co.uk/classic-car-tyres/ferrari/mondial.html so any data and imagery people might have would be gratefully received
  2. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    409
    Eastern Tennessee
    Howard Scott
    From what I have read and been told, they went to 16" wheels midway through the 1987 model run. My car, made late in the run, has factory 16's on it.
  3. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    This is what I have from the various Owner's Manuals (note their Ferrari Document numbers):
    Image Unavailable, Please Login Image Unavailable, Please Login View attachment 2714375 Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Dino2400 likes this.
  4. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #5 Wade, Jun 4, 2019
    I'm sure there's more Owner's Manuals in addition to these.
    From what I see the 16" P7 is specified for the Mondial t, and obviously it's period correct for all Mondials using the 7J x 16" wheel.
  5. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  6. Dino2400
    Dino2400 Formula 3
    Feb 21, 2009
    1,297
  7. davem
    davem F1 Veteran
    8,243
    Stepford, Connecticut
    dave m
    I could fancy some P7 tire porn from back in the day!
    Show us what you got...
  8. AUDIO RESEARCH
    AUDIO RESEARCH Formula Junior
    Feb 11, 2009
    355
    PHILIPPINES
    LUIGI RAYMUND LIRA
    Hi Longstone Tyres ,
    My car is an 88 USA 3.2 cabriolet , my car still has the original spare tire ( Goodyear Eagle ) . Same as fellow member Dino 2400 . It’s a good thing your manufacturing / making the original tires for the Classic Cars .
    Luigi
  9. 2cam
    2cam Formula Junior
    Aug 28, 2014
    743
    Austin, Texas
    MikeS
    Those P7s look geat. I had considered the modern P7 when replacing my tires at the end of last year, but didn't care for the sidewall design. It just didn't look right to me and I went with a set of Coopers instead that matched the specs that I was looking for and also had a more period-looking sidewall.
    It's good to see that these (resissues?) are available in the original design.
    2cam
  10. Longstone Tyres
    Sponsor
    Feb 2, 2006
    1,812
    Dougal
    Oo. sorry i think that is wrong. The P7 is a period side wall design. The side wall design did change a bit in period but the design on the side wall is Pirelli making the tyre so it loooks as close as possible to the way it did in period.
    this is a period advert
    this is a picture we took of our current tyres
    this is another period advert.
    However i don't think the Cooper is. I think they will be totally modern
    However the difficulty is that you guys want a 225/55R16 as a rear tyre and we only have https://www.longstonetyres.co.uk/classic-car-tyres/ferrari/308/225-50yr16-pirelli-cinturato-p7-n4.html which is a shame. Sadly it is nearly an inch smaller in diameter
  11. theunissenguido
    theunissenguido Formula 3
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
    Hi, Dougal
    I did put the new michelin 390 tires on this week on the original wheels. Looking good, just a note : for balancing we did need a lot of lead on each wheel ...about 120 grams, at the outside and the same on the inside. The tire man seas its not the wheel but the tire.
    Guido
  12. Longstone Tyres
    Sponsor
    Feb 2, 2006
    1,812
    Dougal
    hmm! that would be remarkable if that was the case all Michelin tyres are tested very thoroughly. In my mind 120g is erring towards maximum weight i would want on a wheel.
    Might i be right in guessing that the weights are almost 180 degrees apposed to each other?
    And if you found that all the tyres were dramatically out of balance, then try another balancing shop.
  13. theunissenguido
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
    No, that is just odd...it is all at the same level outside and inside...will try an other shop for verifiing.
    Guido
  14. Longstone Tyres
    Sponsor
    Feb 2, 2006
    1,812
    Dougal
    what i'm guessing is that on the outside of the rim you might have a load of weights at the top, then on the inside of the rim you might find a load of weights at the bottom?
  15. theunissenguido
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
    No, all on the top, inside and outside...I will take some pictures. But its not a pretty sight with all that lead.
    Guido
  16. theunissenguido
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
  17. theunissenguido
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
  18. Longstone Tyres
    Sponsor
    Feb 2, 2006
    1,812
    Dougal
    I would go to another wheel balancing place.
    I don't think that 120g per wheel is absolutely terrible. for us 120g is the border line. if we need 120 g we would spin the tyre on the wheel. if it is just 115g then its fine. It is odd to have that much with a Michelin. It also looks worse because they are zinc weights which are just bigger.
    It is worth looking at the wheel on the balancing machine as it spins. to check for trueness.
    There will always be a slightly heavy part of the wheel, and a slightly heavy part of the tyre, and they sometimes land together which is unlucky, but can be fixed by spinning the tyre round 180 degrees on the wheel.
    you can only truly test a wheel with out the tyre on and check the bead seat - the bit where the tyre sits on the rim.
    Try another garage. they might even be able to balance them without having any weights on the outer bead seat.
    theunissenguido likes this.
  19. Longstone Tyres
    Sponsor
    Feb 2, 2006
    1,812
    Dougal
    I thought you might find this comment interesting
    "I took your advice and used the P7 set up suggested for the late Mondial 3.2 on my 1989 328 GTS. (same tyre dimensions). Perfect period look, ride, and handling. Thanks Dougal."
    which was just posted on this film
    I was a little concerned aboout the diameter of the rear beinmg a bit small, but as you can see in the film the P7 225/50R16 Pirelli is the smae diaameter as the 240/55R390 TRX so your gearing should be OK.
    Don't get me wrong i am still a massive fan of the TRX. and i would want TRX on a Mondial if i had one. the TRX drew incredible ride quality from such low profile tyres. But if you are on 16" wheels there is no need to sacrifice the handling by fitting inappropriate modern tyres carcasses, that are designed to be used on a different kind of car. I was very pleased to receive this comment backing up my views
    Rosey and Mark C Harvey like this.
  20. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,614
    Australia
    Mark R
    Hey Dougal, that was me who posted that comment :)
    As promised I'll finally get around to emailling some photos of my 328 with the new tyres on to add to your website page.
    Cheers mate,
    Mark
  21. Longstone Tyres
    Sponsor
    Feb 2, 2006
    1,812
    Dougal
    Hi Mark
    Got them. Thank you they are great
    Rosey likes this.
