12C --- 812S 830 HP @ 9250 --- 800 HP @ 8500 678 Nm @ 7250 --- 718 Nm @ 7000 1665 KG --- 1630 KG 8 gears --- 7 gears 48.4% - 51.6% --- 47% - 53% On paper the best upgrade will be the transmission, the ratio will be shorter meaning more shift and more fun in the streets. The increase in power is disappointing as the peak torque is now lower. In top of that + 35 Kg on an already heavy sport car. Weigh distribution is slightly better, slightly better gravity centre, slightly better cornering, but not sure it will be noticeable, specially with 35kg more to carry. As good as the F140 is, this engine was introduced in 2003 with the Enzo (6.0 at the time) In my opinion the best upgrade was on the 6.3 version to the FF / F12, specially on sound with the equal length. On the 812 we had an upgrade too at 6.5L with better HP and Torque. With the 12C we don't get that much, I am grateful that Ferrari didn't took the hybrid road for the mid front V12 lineup, but I am also disappointed that they increased the HP to look good on paper at the top torque expense. For the weight I really hope that it's not related to a +20cm width as we can read by comparing the width data, but still +35KG in our face. Future Ferrari V12 I hope that Ferrari will introduce a new NA V12 of 6.5+ displacement and 4 digit HP in the Laferrari replacement. Cosworth developed in the last years a 1000HP NA V12 that revs to 11.100 RPM for Aston Martin and now a NA V16 for the new Bugatti. It's time for Ferrari to wake up and stop using a 21 years old V12 design. Ferrari V6 Ferrari is just using emissions regulations as an excuse. They chose to cut down 2 cylinders to add a lot of batteries, instead of sticking with their iconic F154 V8. The F154, their best engine of the past 25 years, with a V6, while big sedans and SUV from Audi / Mercedes / BMW can still be ordered with V8s. (even the C63, a compact sedan will have a V8 again) Ferrari and Maserati should have never given up on the V8's, if anyone should have held out, it should have been them, and they are the first ones to put it on the trash.
You should give the 812 the weight distribution advantage- the slightly greater rearward distribution is preferable for sporty driving. Sent from my iPad using FerrariChat
@Caeruleus11 I agree, I was hesitant between better gravity centre and better power down in RWD, specially in DCT off. The engine side keep getting heavier, for the rear mid engine it was imo due to the increase displacement in the Speciale, then added turbo, hoses, and intercooler in the Pista (Thou I'm not sure about the intercooler location as I'm writing) Scuderia 43/57 Speciale 42/58 Pista 41.5/58.5 296 40.5%/59.5 With mid-engine models, the front-end weight ratio is increasing. The 1% difference between the F12 / 812 is likely due to the larger displacement, there was also a larger displacement between 599/F12 but in that case the complete transmission change is to take in consideration. For the 12C it seems Ferrari is prioritizing comfort features over handling, preferring adding weight. With so many people happy about the Purosangue, praising spider versions (on aluminum chassis LOL), and not minding the shift to a V6, it’s hard to expect anything but less and less sporty cars in the future. 599 47/53 F12 46/54 812 47/53 12C 48.4/51.6
Not sure what the gear ratios are but the 8th speed may just be for very low RPM cruising as an overdrive with the lower gears not different enough to say it would behave better. Neither car is aesthetically appealing as they both show Manzoni lack of design talent. The item not discussed yet is the bulbous arch over the rear wheels. So out of place that can't unsee it.
@Solid State Totally agree on 12C design, looks like a bubble tire lol. I don't want to defend Manzoni, but by looking in his wiki page he seems to have been involved in every design since the FF, so in a lot of gorgeous but lately mainly disastrous ones (special mention on SP3). What do you think of 296 GTB design? I hate the fact that it looks like it is a spider, and in top of that it doesn't have half the presence of the 488/F8. For the gear ratio I recommend to watch the video "DRIVING DYNAMICS - FERRARI PORTOFINO M" in the media gallery (near the bottom of the page) https://www.ferrari.com/en-EN/auto/ferrari-portofino-m
The engine power point is irrelevant IMHO. 800+ hp is more than enough for the street. If you want to play HP top trumps get something else. The V12 is meant to be a grand tourer, in the grandest style. That’s what the 12C is on paper. Sadly the exterior design is a failure and the interior is a disaster. But IMHO, the powertrain is spot on and will provide some compensation for the weaker attributes. Having said that, I still don’t understand why Ferrari chose not to include a real big red start button. Just as the engine is one of the last truly pure V12, so the act of pushing a real button provides a symbolic connection to the beating heart of the beast that no touch pad can replicate.
@subirg So explain why Ferrari complicates things with choices like a wet sump and an extended hood with the engine behind the front wheels? Cause they aim for a front mid-engine V12 that’s both a comfortable cruiser and track-capable, (though the weight limits track endurance). But as there is sadly more customers like you than like me, they please you with spider version, sunroof and other comfort features at the handling expense. Your comment is silly, cause why not having stopped at 360m power? 400HP is already more than enough for the street. You seem to be the type of customer that order a spider with all the options to feel good cruising at 70km/h, I am the one who not even take a lift to save 15kg. You're the poser, I am the driver. And I would have nothing against the posers if they were not influencing Ferrari in the bad direction (at least if you not have a Purosangue in order, or a Roma in your garage you're not the worst.) I agree with you on exterior and even more on the interior, they lost the Ferrari feeling they so brightly accomplished in almost all their interior until Roma. Agree as well on the start engine button, (and even even more on the power steering (since 812) vs hydraulic ones, but again, sadly nobody care about that)
I love it when people assert that anyone with differences are poseurs. “I am a true enthusiast and don’t need air conditioning - if you want air conditioning so you can comfortably drive your street legal car in comfort, you are obviously a poseur. I buy street legal cars to drive on the track with no regard for comfort so I am the enthusiast!” LOL Sent from my iPhone using FerrariChat
@jumpinjohn Come on! Why play in safe by mentioning an imaginary AC choice that doesn't even exist and not comment on Spider, Aperta, GTS versions? So a large part of Ferrari owners aren’t posers but they happily add almost 100kg to their F for essentially a big open sunroof? They are so dumb they often not even realizing how much it weakens their aluminum chassis, despite heavy reinforcements. I'm under attack cause what I say is true and it's hurt. Most F owners (meaning most people here) just want the brand image, cruising with the yellow logo on the wheel and don't hesitate to botcher their F capabilities for a bit more exhaust sound, more attention from other people, and most of them dare despise Lamborghini owners. as you said "LOL"
Well in your book I’m a poseur for sure! After being in this sad state of being, created by your assertions, I have come to admit that I only care that people see me in a Ferrari. It makes me feel important in the world for sure. The days I drive the pickup or jeep are sad days for me. My only respite is that I could be in a Ferrari. But that doesn’t really work because I need affirmations from other people. Perhaps a bumper sticker would help? I don’t know… I’m so ashamed that I don’t track my cars. I’m ashamed that I only drive relatively short distances. I’m ashamed that I spend 60+hours per week working instead of hanging at the track with hard core Ferrari cars. I’m ashamed to admit that sometimes in my 812, I listen to classical music. I’m ashamed that I utilize the heated seats in the F8. I’m ashamed that I had the 355 sent in to service the AC. Worst thing is that I would love to have an 812 GTS to enjoy drives in the cool evening with the wind running over my bald aging head while listening to the glorious notes of a V12 Obviously I am unfit to own a Ferrari. Because I am unworthy of the brand. I am simply a poseur. [emoji20] Sent from my iPhone using FerrariChat
60+ a week… what a sad situation. You’re working so much that you can’t enjoy all the things you’re working for. Gesendet von iPad mit FerrariChat
@jumpinjohn You felt the need to attack me because my comment struck a nerve (and it clearly did). First, you tried to undermine me with a poor example (AC) to mock my point, and now you're resorting to sarcasm and exaggeration. Meanwhile, I'm just calling things as they are. I’ll give you the benefit of the doubt that you genuinely need a pickup / Jeep, if not, don't forget to feel ashamed for that too! Being quite busy seems the only thing we share. Tracks are great, though they can get a bit repetitive after a while. Personally, I find rallying more thrilling, but I don't have the time to dedicate to it as I’d like. And of course, rallying isn’t really relevant here—it's not like I’d ever take my F cars on a rally course anyway. It's like the complete scandal of Ferrari switching to EPS. Probably over 90% of owners don't even realize it since they can't tell the difference between a numb fast rack and a fast hydraulic one.
I know! The good part is that I do love my work. The plan is to reduce it so we can do just what you said, enjoy some driving and other travel!! Sent from my iPhone using FerrariChat
You are correct that it struck a nerve but not the one you may be supposing. I am particularly put off by snobbishness. Your comment struck me as being snobbish by categorizing other Ferrari owners who desire or drive models that you don’t particularly like as being stupid and/or poseurs only wanting to be seen in a Ferrari. That may not have been your intent, but that’s how it struck me. I know you were joking about the Jeep and truck! Haha! Some in Jeep world would call me a poseur because I never go “off roading”. There are snobs everywhere! If I only had one vehicle it would be the truck which is all I drove for years. But I really enjoy driving these cars - even with EPS. Would I like hydraulic better? Yes, but it doesn’t hurt my enjoyment. Can some people tell the difference? Yes and some cannot. Doesn’t mean bad things about them. And that was my point. Anyhow, I made the assumption from your comment that you are just another snob and had some fun with it. Didn’t mean it as an attack. My apologies if that was a wrong assumption. Sent from my iPhone using FerrariChat
@jumpinjohn It's true that I was joking about the Jeep and trucks, but I don’t get why people are into them. I’ve never driven a truck in my life and never felt the need to, especially since I hated the few SUVs I test drove. As for categorizing people, I won't deny it—that’s exactly what I did. You seem hesitant to offend people and that’s an issue. You can’t be truly honest without occasionally offending someone. If more of us, the owners were vocal about the lack of feel with EPS, things might actually change. I get why BMW and Mercedes only offer EPS in their M and AMG models—those are just sportier versions of regular cars, so that’s how they were designed from the start, don't like Porsche but every purist would agree that the story end with the 997. This ESP is a tragedy, I regret it for Lamborghini, I’m sad about Maserati, and heartbroken over Ferrari. How did they decide to go this route? I mean, “no more V8s, and EPS across the whole lineup? For the first time, I’m seriously considering buying a McLaren, probably the 750S and all because of the 296GTB, it's like they betrayed me.
I don’t disagree with the change in direction or even the regrets of it. I’m not afraid of offending but don’t like to do so needlessly. Things change. All changes are not necessarily progress. Not much to be done about that. So I choose to enjoy for what they are. I’m still playing with the idea of trying to qualify for a special car. Might try or might not. I’m leaning toward keeping what I have and getting a Singer Turbo Study. If I’m gonna blow big money, get something uniquely mine with a manual and modern brakes! I also like that most people would have no ideas what it is. Sent from my iPhone using FerrariChat
I still want to believe that there will be a v8 again someday, maybe a decade from now, and hope a new v12 in the Laf replacement despite all the rumors against it, maybe I'm delusional. I didn't know about the Singer Turbo, really nice looking car, and should be amazing to drive but imo not a $1M car, for the perfect manual and few more bucks I would go CarreraGT, or even FordGT. The ideal move would be to create your own project. About 10 years ago, I had thoughts of doing something with the F136 cross-plane or the S85 because those engines deserved a much lighter body. Dropping the S85 into an i8 would have been incredible, but that would have meant cutting into the carbon chassis, and in the end, trying to fit that engine into the front of another BMW just wasn’t worth the hassle. Alternatively, you could try converting an FF or GTC4 Lusso to RWD, but that would probably run you over $1M lol.
Hate to keep derailing the thread… I have looked into creating the unique car, but for a top job, it is gonna be in the $500k and up for something that is probably going to ever increase in value. I have an excellent Ford GT and absolutely love it, but it is not a practical semi DD. I loved the 911 930 turbo as a younger me and the Singer recreates it with modern improvements. I drove a Classic study and toured their facility, coming away quite impressed. Best I can tell, they have retained their value and production is limited, so I can justify those dollars. (Give me enough time and I can justify almost anything!) I think I could drive that every day and nobody would think it is anything but an old 911, which would be kinda fun! Cheers! Sent from my iPhone using FerrariChat
Seems like an excellent idea to me. Small, fast, iconic, not so easy to drive, reveals its secrets with time, modern and reliable…plus, you get to choose exactly how it should look and feel inside and out. What a great concept. And as for the 930 Turbo. It’s a brilliant car.
Hey I like Jeeps! Not the poseur Grand Cherokee SRT type things but the lifted, steel bumper, winch wielding freaking winter supercar for hairy chested guys like me who actually look forward to heavy snow days in winter. Then when winter breaks- I love the wind in my hair(yeah I still have it) when driving my GTS on roads like it was designed for and couldn’t give a rats ass what other Ferrari drivers think of me. McLaren? Well as the dealership head repair guy told my wife while I took a 720S for a test spin, “it’s a British Car… and all the repairs that go with em”. It’s a shame though, carbon fiber tub, light weight…that is great. Maybe an Alfa 4C…spider of course… I must be delusional Sent from my iPhone using FerrariChat
Hate to break up a nice fight Can I ask if the 812 performance specs include the GPF? Early production US cars did not have to be saddled with the GPF. This horrible piece of progressive regulatory lunacy imposes a significant reduction of performance with zero gain in a world of greater particulate production from the tires of much heavier and higher torque all electric vehicles . Okay now I feel better
I'm not sure they did not manage to maintain the performance when adding the GPF, by tuning the engine management. The F8 engine with GPF claims exactly the same performance figures as the Pista engine without GPF. I think in Europe the GPF was introduced on the 812 SF with the release of the 812 GTS.
While I loved the GTB design, I concede that a surprising amount of people asked me how the targa top comes off or folds back. "Oh, this one is the hardtop. There IS a convertible that looks basically the same, where this part folds back into the deck, but not this version..."
The GPF combined with turbos in the F8 silences the engine music. The turbos are also impacted. The early US 812s did not have the GPF and they sounded much nicer. Since this model didn’t use turbos we got to hear the traditional V12 engine music. The interesting innovation which is introduced in the F80 is electric turbos. Theoretically this would not muffle the exhaust but alas there is still the GPF in place.
