100 Octane Fuel | FerrariChat
100 Octane Fuel
Discussion in 'Ferrari Discussion (not model specific)' started by 410SA, Sep 9, 2005.
  1. 410SA
    410SA F1 Veteran
    Nov 2, 2003
    8,511
    West Coast
    A
    With gas prices risng rapidly, racing fuel at $6 per gallon doesn't seem so crazy.There's a Union Gas at the corner of 56th St and Bell that has a racing fuel pump. I think there's also racing fuel available at Cave Creek and Union Hills, for greater Phoenix residents.
    Is there any quantifiable benfit to running 100 octane gas, or even mixing it it into half a tank of 91 octane?
    Is the answer different for fuel injected cars versus carb cars?
  2. bostonmini
    bostonmini Formula 3
    Nov 8, 2003
    1,890
    Alex, I know NOTHING about it, but i suspect one benefit for a car like one of urs (F40) would allow a boost pressure increase without knocking...no?:)
  3. Kevallino
    Kevallino Formula 3
    Feb 10, 2004
    2,257
    Mid-Ohio
    Kevin
    We had a thread about this in the SoCal section - I run 1/3 tank of 100 octane in my Eurospec 380SL in the summer to prevent detonation and it def. works. In theory the EFI cars should have the computer dealing with the A/F mix although it depends a bit on the generation of computer and the tunability thereof. In a carb car it ought to let you get more aggressive with timing with more octane. I've not run the 100 in my 348 or the Porsche as they are both US EFI.
    Cheers
    Kevin
  4. zsnnf
    zsnnf Formula 3
    Sep 11, 2003
    1,877
    Most of the Union stations that are selling 100 Octane here are less than $6.
    I think it's a good deal compared to the dollar amount 91 has gone up.
    Alex, Your F40 will LOVE 100 octane. Mine does. Just a 20% mix makes a big difference. With the stock motor we saw an increase of 45 rear wheel H.P. I believe the F40 was designed to run on 93 Octane. Anything less and the ECU's will reduce timing and boost.
    It will also help with Carb equiped cars. Especially with the idle quality. 91 octane (modern fuel in general) has so many oxygenates in it that it has a very low spacific gravity and requires much more fuel to allow an engine to run. Adding 100 will help with this.
  5. 410SA
    410SA F1 Veteran
    Nov 2, 2003
    8,511
    West Coast
    A
    Thanks Rick. I'm going to put some into the F40 this weekend and I'll definitely put a few drops into my 77 carb 308 GTB. My son is learning to drive stick in it and anything that helps the car keep running as a 15 year continuously dumps the clutch too quickly, will help.
  6. Doug.
    Doug. F1 Rookie
    3,266
    Las Vegas, NV
    What about running oxygenated racing fuel?
    Would that help against detonation while still improving performance?
