1/2 inch torque wrench recommendation | FerrariChat
Discussion in 'Technical Q&A' started by yelcab, Oct 28, 2018.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    I have a really nice and pricey electronic Gearwrench 1/2 torque wrench that does Nm, Ftlb, and degrees rotation with a flex head. It's always in a case, inside a cabinet, and only comes out when really precision work is needed between 100 - 250 lbs. Well, it went tits up on me, won't even turn on with brand new AAA batteries. This is the second electronic torque wrench that has done this bull **** and I am DONE with the effing electronic torque wrenches. I am keeping it in my car so that I can pitch it over the side of the Golden Gate bridge the next time I cross it.
    I want to buy a mechanical clicking type that goes up to 250 lbs, 24 inches long minimum, and I am not sure what to buy. Choices are:
    1. Used SnapOn 250lbs wrench (not paying for new ones.... )
    2. New Gearwrench 1/2 inch 250 lb wrench
    3. Others ????
    Any insight, recommendation, and / or brain farts is appreciated.
  2. zygomatic
    zygomatic F1 Veteran
    5,050
    Washington, DC
    Chris
    What are you going to use this for?
    I have a Tekton 1/2" click torque wrench that is mostly used for wheel bolts / lug nuts. I know S/O and others are more accurate and better made. For what this is used for, at $50 it was a good buy and hasn't let me down.
  3. zygomatic
    5,050
    Washington, DC
    Chris
  4. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    You get what you pay for, Mitch.
    Two words - Snap On.
  5. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    490
    Victoria, B.C, Can.
    John Glen Wesanko
    Snap On for sure. Remember to get calibrated.
    Keith Darby likes this.
  6. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    SoCal LA/OC/New Mexico
    Tim Dee
    I use digital snapon and get it calibrated yearly here at a digital instrument place in the area for $50
    Useally within 5 pounds
    Btw the rotation degree is widely used after torque
  7. ago car nut
    ago car nut F1 Veteran
    5,462
    Madison Ohio
    David A.
    The beam type is basically a spring and is more rugged. I double check my torque wrenches against each other. Put a bolt with nut in vise and try one wrench against another. You know that bolt torque is affected by lubrication or lack of on the thread. So I wouldn't get to concerned 100% accurate torque. Measuring bolt stretch is more accurate. Over tightening is bad.
    bisel likes this.
  8. bisel
    bisel Formula 3
    1,138
    Scottsdale, Arizona
    Steve Bisel
    #9 bisel, Oct 29, 2018
    Beam type very good, very reliable, but does not have a nice click when reaching set torque. I have a Craftsman dial in type. No batteries.
    Steve
  9. yelcab
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    Let me add more information.
    I have seven torque wrenches from SnapOn 3/8 and 1/2 balanced beams, Precision Instrument 3/8 balanced beam, Husky 1/4 clicker, and Craftsman clicker types, and the now-dead electronic Gearwrench one. One is dedicated to 75lbs for torqueing wheels only. Four are used for high quality precision work to 150lbs. Occasionally, I need to go beyond 150 lbs (axle nuts, gearbox nuts, big ass wheel nuts) and that is when I pull out the big Gearwrench electronic one that is now dead as a door nail. No more electronic garbage (and I hold a MSEE).
    I bought the electronic one thinking that the degree rotation will come in handy but I have found its use to be finicky and inaccurate especially if you have to take multiple passes to get to the final degrees. So, I rely on my Snap On mechanical degree gauge for that. Or, simply mark the nuts/bolts. So that feature is not important anymore.
    So, now I am looking for a 24 inch long (so I can use the leverage), 1/2 type (big sockets), clicker adjustable mechanical type (no more batteries), that is of good quality and will last a long time. CDI is now making Snap On so I would just buy from CDI instead of a new Snap On.
  10. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    [QUOTE="yelcab, post: 146276084, member: 211"
    So, now I am looking for a 24 inch long (so I can use the leverage), 1/2 type (big sockets), clicker adjustable mechanical type (no more batteries), that is of good quality and will last a long time. CDI is now making Snap On so I would just buy from CDI instead of a new Snap On.[/QUOTE]
    Yeah I know you need one of these.
    Not mine just an example. I think the newer one is better gets better battery life from an update. Plus it has the degree wheel on it also
    I use these on Diesels with big ARP studs in the 200 lb range
    Same guts as another model I forget the name
    https://www.ebay.com/itm/Snap-On-1-2-Drive-Electronic-Torque-Wrench-TechAngle-ATECH3FR250B/253951850725?hash=item3b20b5b8e5:g:ROsAAOSwlY5b07Kv:rk:5:pf:1&frcectupt=true
  11. yelcab
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    https://www.ebay.com/itm/Snap-On-1-2-Drive-Electronic-Torque-Wrench-TechAngle-ATECH3FR250B/253951850725?hash=item3b20b5b8e5:g:ROsAAOSwlY5b07Kv:rk:5:pf:1&frcectupt=true[/QUOTE]
    How long have you had yours?
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    I think 4 years or so
    I upgrade to the latest ones all the time, have 3/4 and 1/2 in these no 1/4 as I dont do that work anymore
  13. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  14. jgmblair
    jgmblair Formula Junior
    778
    Winnipeg, MB Canada
    Jeff Blair
    Does your wife have a sister ;)
    taz355 and Dave rocks like this.
  15. Challenge
    Challenge Formula 3
    Sep 27, 2002
    1,997
    PA
    Kevin
    I got the big Tekton clicker that goes to 250 lb ft. Only need it for axle nuts but it seems to work well.
  16. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Sorry but no... I certainly got lucky, that's for sure.
  17. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,938
    I use SK-Wayne click-type; I have 3/8, 1/4 and 3/4 (the 3/4 was only for my Testarossa, haven't used it since). They work great. I also have an angle adapter for when I do torque/angle measurements.
  18. sandreb
    sandreb Karting
    Feb 7, 2018
    52
    Sander B.
    I use and recommend Precision Instruments torque wrenches.
  19. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    Harbor Freight has some good quality ones. Top notch.
  20. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Harbor Freight doesn't have good quality anything. Inexpensive, though.
  21. f355spider
    f355spider F1 World Champ
    18,026
    Utica Tools makes professional grade torque wrenches used in manufacturing and trades. I have had mine (home use) for 30 years. Every time I have the calibration checked it is spot on. http://uticatorquewrench.com/about-us.html
    http://uticatorquewrench.com/utica-ratchet-head-torque-wrenches.html
    Whatever you buy, (especially used) have the calibration checked. I had a friend buy two new Craftsman torque wrenches and had them checked and both were out of calibration right out of the box.
    I have purchased a second used Utica Tools torque wrench off Ebay and immediately sent it in for testing and calibration. Not expensive and they return with a certificate with calibration % in each direction.
  22. f355spider
    18,026
    Consider a used Utica Tools 1/2" drive is $400+ new, but you can find them for $40 to $50 on Ebay. Send it out for calibration (factory or local) and you should be able to have a decent used one for 1/4 the price of new. Even if it needs a new ratchet head, you wouldn't be into it more than $175 to $200 total.
  23. yelcab
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    I snatched a SnapOn 1/2 inch 250lbs used torque wrench off Ebay. I will post picture when I get it.
    Since I am in a buying mood, I will make an offer on a Utica 3/4 inch 600lbs model
    f355spider likes this.
  24. f355spider
    18,026
    I think if you can find your local Snap On dealer, they have a tester and can test and calibrate on their trucks. Not sure if they service one from another manufacturer. Worth asking. A friend told me Snap On dealers only test, cannot calibrate
