track day protection | FerrariChat
Discussion in 'Tracking & Driver Education' started by [email protected], Jun 21, 2009.
  1. doctp12@aol.com
    Nov 4, 2003
    59
    I have a track day coming up in July and will have my Stradale out all day. The front end has perfect paint as well as the Clear Plastic Protection 3M tape pretty much everywhere.
    What should I use to protect the nose and other areas from pebbles on the track? I have seen lots of drivers placing "Racing Tape" all over the nose. Should I place this over the "Clear 3M Plastic"? What type of tape do you recommend? Will the tape pull off the 3M clear bra at the end of ther day?
  2. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,826
    Jupiter, FL
    Paul Bianco
    IMO, the 3M tape should be good enough. for the others areas you can use blue painters tape.
  3. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    I track my CS often. After two track days, the car had more spots than a Dalmatian. I spent several hours rubbing off rubber marks from the nose and sides. The tape would prevent that.
    Even the sides protected with clear film were chipped when I went off track and kicked up gravel. Adding tape over the clear film may help.
  4. apexdc
    apexdc Karting
    Jan 6, 2008
    147
    Palm Springs, CA
    David Christian
    #4 apexdc, May 9, 2011
    Try TrakkTape. Great temporary protection and not as ugly as blue tape.
    Some of the clear 3M tapes have pretty aggressive adhesives. TrakkTape is intended to be for temporary protection of nice surfaces, so it is sticky, but not too sticky.
    www.trakktape.com
  5. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,237
    Austin, TX
    Randy
    Whichever you use, don't neglect covering behind the wheel wells, as the tires turn they can kick up gravel and clag.
  6. arizonaitalian
    arizonaitalian F1 World Champ
    Oct 29, 2010
    19,997
    Wyoming
    but well worth it!
    I got rubber marks all over mine...took two detailing sessions and a wax job to get it off. The side skirts got the worst of it actually. And you will get paint chips in all sorts of places. Flying rubber was the worst, but all sorts of stuff comes at you. I taped the lower sides and it helped a lot, I used some sort of "track tape" that they sold at the track made specially for this because it would not leave sticky residue...and...of course...it left tons.
    Experienced folks at the track said "go get blue painters tape at Lowe's" and it will work better for you. Next time...
  7. apexdc
    apexdc Karting
    Jan 6, 2008
    147
    Palm Springs, CA
    David Christian
    If your car flares out in front of the rear wheels, that area gets blasted with debris coming off the front tires, as well. It's a good idea to do more than one layer of whatever you are using in those areas.
    Debris from the car ahead has a little time to lose energy. Not so on things coming off your own tires.
    Been using TrakkTape on one of my student's 458 Italia with good results.
  8. neetad
    neetad Rookie
    3
    I have been working to find a better solution for track days than the typical goofy Blue Tape. After trying a number of products over the last year, I think I have a better option.
  9. rydermike
    rydermike Formula Junior
    Mar 27, 2010
    416
    Spring Hill,FL
    Mike Donohue
    Perhaps get the tape made in a glossy red ? I've often thought the same with the blue tarps seen after major storms tear an area up , why dosen't somebody make these tarps with about 4 different rood tile color patterns ?
  10. henryr
    henryr Two Time F1 World Champ
    21,692
    Atlanta
    Juan Sánchez Villa-L
    trakktape is garbage......
    trackwrap.com
  11. DCNSX
    DCNSX Formula Junior
    Feb 5, 2007
    639
    Winston-Salem, NC
    It can also be important to remove rubber marks from your clear-film VERY SOON after the track day. After one weekend, I waited until Wednesday to wash the car. I rubbed and rubbed soap and water trying to remove five rubber marks from my hood. The result is I have worn scratches in my clear-film. Not sure if a detail guy can get this off. If not, I'll have to have that panel of film replaced.
    One track buddy recommends Simple Green (solvent/cleaner) on the clear-film. He just sprays it on right at the track and wipes off the rubber immediately.
  12. staatsof
    91,579
    Fuggetaboutitland
    Bob
    What do you recommend instead? Your reference above goes nowhere.
  13. staatsof
    91,579
    Fuggetaboutitland
    Bob
    Turtlewax bug and tar remover with a wet rag works really well.
    I used to use one of those wet your car and then spray on the instant wax combos to wax my track car ahead of time as that really helps keep the junk from sticking so badly.
    I always clean my car completely right after my last session and put that instant wax on it .
    Rainex on the glass.
    If you're going to do this a lot get a peel off protective film for the windshield. They're available for a lot of cars or you can have one made or get a generic piece and fit it yourself.
    It's not a concours wax and detail job but it really helps.
  14. henryr
    21,692
    Atlanta
    sorry
    tracwrap.com
  15. apexdc
    apexdc Karting
    Jan 6, 2008
    147
    Palm Springs, CA
    David Christian
    Hi,
    Just curious what your bad experience was with TrakkTape?
    Thanks,
  16. henryr
    21,692
    Atlanta
    side by side...tracwrap is just a far superior product. it is very thick, pliable and sticks very well - run, sun and shine and especially at speed.
  17. blockbuster
    blockbuster Karting
    Nov 26, 2006
    158
    U.S.
    Where can I buy Trakk Tape?
  18. henryr
    21,692
    Atlanta
    trakktape is garbage u want tracwrap........... i think its tracwrap.com
  19. apexdc
    apexdc Karting
    Jan 6, 2008
    147
    Palm Springs, CA
    David Christian
    Trakktape.com
    Try a roll. I have a LOT of satisfied customers. If you don't like it, I'll buy it back.
    Also, check this thread:
    http://www.1addicts.com/forums/showthread.php?t=588565
    and this one:
    http://www.1addicts.com/forums/showthread.php?t=563895
    If anyone wants a large roll, 600 feet x 6" wide x 5 mil thick, use Racers Net code on the above site. Normal price of $145 will then be $120. Use FC120.
    Email me with any questions at [email protected].
    Thanks for the interest!
  20. apexdc
    apexdc Karting
    Jan 6, 2008
    147
    Palm Springs, CA
    David Christian
    Hi,
    For TrakkTape, (the leading track day protection ), the Racers Net code FC120 now only works here.
    Ordering
    I needed to protect my other distributors, so took it off the main TrakkTape site. This allows me to still offer the $120 6 inch by 600 foot roll, instead of the normal $145 retail price.
    Watch for others using TrakkTape at the track, as that is our best referral. We are also proud to be endorsed by Hooked on Driving nationwide and available on their web site, as well.
    As always, email me (David) [email protected] or call at 760-285-2220 with any questions.
    100% satisfaction guaranteed including return shipping, and if you spot me at some event in SoCal, I'll even buy you lunch!
    Have fun on track!
  21. mswncity
    mswncity Karting
    Feb 10, 2012
    58
    Hailey, ID
  22. davem
    davem F1 Veteran
    8,244
    Stepford, Connecticut
    dave m
    To keep break dust and clag sticking to your wheels, wax them liberally. Don't buff it too much, as the generous amount of wax will help protect better.
    Works great.
  23. Rosso328
    Rosso328 F1 Veteran
    6,831
    Central FL
    Paul
  24. jcurry
    21,572
    In the past
    Jim
    No experience with other products but tracwrap (tracwrap.com) is made by XPEL which is what I have over the entire front end of my 360. This past weekend used tracwrap to cover some areas that needed some protection based on prior track day. Easy to put on. As noted is very thick, yet pliable. Was on for three days, including track day in sun all day. Came off as easy as it went on.
