Radio Aerials/antennas | FerrariChat
Discussion in 'Mondial' started by UKtifosi, Sep 26, 2017.
  1. UKtifosi
    UKtifosi Karting
    May 7, 2014
    101
    Kent, UK
    Paul Glyde
    Hi, I haven't seen these mentioned before. But has anyone replaced the 'prehistoric' metal radio aerial that slides out of the back with something more modern?
  2. UKtifosi
    UKtifosi Karting
    May 7, 2014
    101
    Kent, UK
    Paul Glyde
    i guess the answer is no.
  3. Cadillacbart
    Cadillacbart Formula Junior
    Nov 26, 2013
    436
    Denver, CO
    I cant help you. I quite like my semi-automatic 1980's antennae.
  4. afterburner
    afterburner F1 Rookie
    3,213
    Hong Kong
    Yes I did when my non-original one broke. I since found an original NOS antenna in Italy, so the modern one is for sale on ebay. It's about a year old.
    If you are interested, I would supply the Mondial specific adapters to you as well. PM me please in case.
  5. UKtifosi
    UKtifosi Karting
    May 7, 2014
    101
    Kent, UK
    Paul Glyde
    Hi, thank you very much . It's great of you to reply. At the moment I don't really need a new aerial as mine works fine, I was just wondering if there was a better way of picking up radio signals as most cars now (including Ferraris) have hidden aerials. Paul
  6. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    yes, I've replaced both on 348 and the mondial with universal units which I get from www.sumitracing.com
  7. UKtifosi
    UKtifosi Karting
    May 7, 2014
    101
    Kent, UK
    Paul Glyde
    Thank you for this, I'll check them out. Paul
  8. ATLdoghouse
    ATLdoghouse Formula Junior
    368
    Atlanta
    Cody L
  9. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
  10. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    autoloc antenna
    www.autoloc.com
    http://www.autoloc.com/catalog/Antennas/Flush-Mount-Power-Antenna/AUTPAC/Chrome-Power-Antenna-Kit
    I will say that I have not figured out how to get the universal to auto raise with the radio power, but that is more of a time issue for me to figure it out. I know people have gotten these and other universals to work like OEM with the switch power or radio power. On my 348 I had to modify/splice the antenna cable. On my mondial I don't recall if I modified the antenna cable. They do require some modification to install, hence the term universal, but can be made to work.
  11. Cadillacbart
    Nov 26, 2013
    436
    Denver, CO
    I think the op is saying he doesn't like the look and function of a metal mast antennae, and is looking for something functional that doesn't look like oem, or doesn't show at all.
  12. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    I replaced the original power antenna in my 85 Coupe, with a replacement that I bought for $65 at a local autozone.
    It was a generic brand, but it looked identical to the original, and was a direct fit replacement.
    As for auto-up and auto-down with radio power-- a previous owner has modified my car so that the antenna does not operate by the console switch. It is instead wired directly to a line coming from the back of the radio (the antenna line). When radio power goes on -- the antenna goes up. When radio power goes off -- antenna goes down. The console antenna switch does nothing.
    Sid
  13. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    My QV is the same way. I've reassigned the console antenna switch to activate my garage door opener.
  14. afterburner
    3,213
    Hong Kong
    Same on mine.
