Poll: How many with 456M have replaced accumulators? | Page 2 | FerrariChat
Discussion in '456/550/575' started by Amalfi Dream, Sep 27, 2015.
  1. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    Jason, the accumulators and the light are not talking to each other.
    If the light stays on it means one or more actuators are not working.
  2. Andrew D.
    Andrew D. F1 Rookie
    Jul 6, 2008
    3,979
    Goodwood Ontario
    Andrew D.
    Taz, my suspension seems to have only one setting,hard. I have bought the accumulators,any special issue replacing. ?system need bleeding?
  3. tazandjan
    38,054
    Andrew- Should not need bleeding. If you bought the BMW accumulators, you will need some washers because the holes are slightly larger.
  4. dencap
    dencap Karting
    Sep 29, 2013
    127
    SF Bay Area, CA
    Dennis Caponigro
    After approx. 20 miles the suspension light extinguished. Now at about 200 miles still no suspension light.
    The new accumulators are providing a much better ride.
    Dennis
  5. Andrew D.
    Andrew D. F1 Rookie
    Jul 6, 2008
    3,979
    Goodwood Ontario
    Andrew D.
    Thans Taz,your the best.
  6. Somersett
    Somersett Rookie
    Sep 30, 2015
    11
    England
    Replaced mine with the BMW units. Car rides and handles great. Having had Citroens and Rolls/Bentleys with similar spheres they progressively lose gas
    and need recharging or replacing every 15 years or their function is impaired.
  7. au-yt
    au-yt F1 Veteran
    5,834
    Burradoo... Actually
    Graeme
    I also replaced mine with BMW units at about 15 years mainly out of unknown history, from Classic Maserati experience 10 years on older type units New units have better rubber compounds
  8. bergxu
    bergxu Formula 3
    Aug 16, 2005
    1,305
    OnTheSerpentMound
    Aaron
    Also did mine earlier this year. Used the BMW ones, sourced online, manufactured by Febi Bilstein. Having spent many years in a past life working on Mercedes, I replaced a ton of them on the TD and TE wagons and the 560SELs.
    If you were to cut one open, you'd see a diaphragm inside. On one side is nitrogen and on the other side is the pressurized oil (ATF in our case). When the diaphragm ruptures, the spheres lose their ability to act as a springing medium and then in turn hammer on the shocks causing, in some instances, the blowout as shown above. I had to put one used shock on a friend's '97 GTA because his split just like the one in the photo.
    Case in point, if the arse end of your 456 isn't nice and 'floaty' it's time to change spheres ASAP!
