Leakdown test results, not good, head re-builder options? | Page 2 | FerrariChat
Discussion in '348/355' started by ThomasK, Sep 28, 2017.
  1. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Why only 18? Were some still ok?
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Whats the other piece.
    How do you get the correct torque or is it torqued by rotations
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    I got it now thanks
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    That is just the handle, the other piece is the stubby 15mm wrench that goes into that handle. The torque wrench fits 90 degrees to that handle and makes the torque reading correct on the wrench. The setting however is a low torque at the beginning and an additional 90 degrees after that.
  5. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    The tool needs to be 2 pieces so when it breaks you only need to replace half. I bought the tool. The issue with these tools is the low volume - that's what drives the cost. Our spark plug boot tool is pretty darn cheap at $60 (you bought one Mitch) but I think we've only sold 20 or so. Hardly worth programming the machine but I do many of these things for myself and just to offer cool stuff for the community.
    Perhaps one day but it's low on the list.
  6. ThomasK
    ThomasK Karting
    Dec 8, 2009
    132
    Houston, TX
    thats probably what mine look like inside. what did you end up doing with that head? clean carbon off and reinstall?
    since i have this engine torn down for a major/30k, i figure i remove this cylinder head. i did get cylinder 1 from 25% to 5% leakdown by spraying some cleaner in the exhaust ports and using a pick and small brush to try and clean. i tried that on cylinder 2 but didnt work, still 25%. plus, i dont know how much carbon bits im dislodging into the bore.
    since ive decided to make the executive decision to pull the head, is there a way i could clean off all the carbon myself with the improved access of the head being removed?
  7. ThomasK
    ThomasK Karting
    Dec 8, 2009
    132
    Houston, TX
    thanks!
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I'm doing a full restoration of the car - hopefully it will be done in my lifetime;)
    I'm Fully rebuilding the heads (myself) and will be installing manganese bronze guides and all new valves.
  9. ThomasK
    ThomasK Karting
    Dec 8, 2009
    132
    Houston, TX
    engine was running perfectly. but i am OCD when it comes to my cars, this amount of leak down makes me want to just pull the head off and inspect.
    i would like to pull the head off and clean up the combustion chamber and valves and reassemble.
    i think much over 10% leak down is a typical for investigation whether its through the valves or the rings. since mine all seem isolated to the exhaust valves, i think this rabbit hole isnt too deep, just get the heads cleaned up and im ready to go.
  10. ThomasK
    ThomasK Karting
    Dec 8, 2009
    132
    Houston, TX
    i would really prefer to get this head off and clean it up, then reinstall.
    the car is a 99 and does have steel valve guides, so i dont think its a valve guide issue.
    just dont know an easier way to get carbon off of the valve seats other than pull the head and get it all removed and checked at the same time.
    i think someone just didnt drive this car hard enough.
    ive also heard of using seafoam injected into the intake? but i dont think i want to rely on that. the subframe is out, everything off ready to go, might as well break into it.
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Tom - unless you need to replace the valves (possible) you can take it all apart and clean. Probably need to dress seats which will result in a slight valve height adjustment. That's a whole other can a worms for the compound angle valves.
  12. joe1973
    joe1973 Formula Junior
    Nov 12, 2016
    285
    NJ
    Two years ago I was looking to buy a 35 from a dealer in NJ. They admitted leak down of the traded in car was not ideal, but the said their move was to drive it for few weeks (Italian for sure) and re-assess compression. In my view unless it's a race car and you need every 10ths performance, there's no need to open up an engine for refresh. Tired valve guides and high oil consumption with visible smoking entirely a different matter.
  13. ThomasK
    ThomasK Karting
    Dec 8, 2009
    132
    Houston, TX
    i would definitely agree with you most of the time. but in this case, all the trouble cylinders are on 1-4 (one head removal only), i started cleaning 1-2 exhaust ports and probably knocked off some carbon bits in the bore i would like to get out, engine is out for a major anyway, i could clean the tops of the pistons, and ive been driving it pretty hard for a year, so i would assume the carbon on the exhaust valves would have cleaned out by now.
    im confident all but maybe 5% of the leak down is due to the exhaust valves, i can feel a lot of air escaping through them. Now is the time to check it out, "while im here"
  14. ducrob
    ducrob Formula Junior
    Nov 20, 2011
    749
    Canada
    Rob
    They were literally rocking in the valve guides. He said the valves were "hammered". They were sent back to me and I gave them away as souvenirs to friends.
  15. phrogs
    phrogs F1 Veteran
    7,130
    Michigan
    For carbon removal I go to my chevy dealer and get the GM top end cleaner.
  16. PaulK
    PaulK F1 Rookie
    4,623
    Michigan
    Paul
    Hi everyone, sorry for the bump but I think this is more efficient than making a new thread. I'd like to clean out any carbon build up in my heads/valves prior to doing a leakdown/compression test to mitigate the possibility of bad compression/leakdown numbers being from carbon buildup.
    This is what I want to buy, correct? If so, how do I administer the dose? I seem to remember reading just to pour it in the intake just after the air filter. Or do I just inject it in the ports that are used to balance the throttle bodies?
    https://www.amazon.com/ACDelco-10-3015-Engine-Injector-Cleaner/dp/B07CZ17LK3/ref=sr_1_2?crid=3Q1RM3EPJ67AE&keywords=gm+top+end+cleaner&qid=1656360889&sprefix=gm+top+end+cleaner,aps,91&sr=8-2
    It is worth noting that this is a 32oz bottle. They also make a 16oz bottle and also one in aerosol form. I am concerned about hydro locking the engine as well as damaging the MAFs. I'd like to know the correct procedure. Thanks!
  17. Ferrarium
    Ferrarium F1 Veteran
    5,637
    Central NJ
    Eric
    On my STI we would draw sea foam into the intake manifold from a vacuum port.
    steved033 and PaulK like this.
  18. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,219
    Los Angeles
    Water > seafoam
  19. PaulK
    PaulK F1 Rookie
    4,623
    Michigan
    Paul
    Thanks! I'll look into sea foam but I did have a friend who had it done to his car and it caused a CEL and high idle.
    I'm not going to use water on this. But thanks for the suggestion
    Sent from my Pixel 5a using Tapatalk
  20. Ferrarium
    5,637
    Central NJ
    Eric
  21. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    7,792
    Atlanta, GA
    Steve D.
    I've done that on a couple cars...One was a 1968 fury, the other an old C10. I smoke checked the neighborhood twice....LOL
    sjd
  22. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,570
    SoCal LA/OC/New Mexico
    Tim Dee
    I have this setup from BG and love it. on my third setup as the first 2 were never returned :)
