Goodbye FF, Hello F12 or... | Page 3 | FerrariChat
Discussion in 'F12/812' started by -CD-, Aug 3, 2017.
  1. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    That interior is gorgeous! That good amount of alcantara also cuts down the leather surface that needs to be taken care of.
    You are definitely really good at detailing, Christian. Just look at the shine on the inner wheel barrel...Wow!
    It's interesting to see the 2-pieces wheel bolts. Is the needed torque for those Ti 2-pieces wheels bolts still the same? I thought the torque depends on both the friction on the threads and also the collar. With the collar spinning around, that means the torque relies solely on the thread. I was told at one time to apply anti-seize on only the threads but not the collar. Then I was told something else and I wiped all the anti-seize off to avoid over-torque. Obviously with the spinning collar, no anti-seize should be applied to the threads. If the recommended torque is the same with the spinning collar on, that means it's safe to apply the anti-seize on the collar region of regular bolt. I'm confused now and will need to look into this subject.
  2. Geneva599
    Geneva599 Rookie
    Mar 13, 2017
    38
    Geneva
    FJZ
    #52 Geneva599, Aug 8, 2017
  3. -CD-
    -CD- F1 Rookie
    3,769
    near the Nürburgring
    Christian
    Only grease...
  4. rockitman
    rockitman F1 Veteran
    May 31, 2015
    5,982
    Upstate, NY
    Christian
    #54 rockitman, Aug 8, 2017
    I went with aftermarket polished titanium 2 piece bolts. The bolt head seems a bit bigger than Ferrari OEM. These bolts make the wheels, imo.
  5. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    What's the wheel bolt size? Is it M14 X 1.5?
  6. -CD-
    -CD- F1 Rookie
    3,769
    Christian
    #57 -CD-, Aug 9, 2017
  7. Mr. Tom
    Mr. Tom Rookie
    Feb 9, 2017
    5
    Germany
    Tom
    Good to see my bolts on your F12. They look just awesome!
  8. -CD-
    -CD- F1 Rookie
    3,769
    Christian
    Thanks Tom! :)
    Paket is on the way!
  9. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    Do you have the factory part number? I'd like to order a set for my GTC4L as they would go nicely with the diamond cut wheels
    Thank you in advance
  10. -CD-
    -CD- F1 Rookie
    3,769
    Christian
    Partnumber is 70001200. :)
    Perhaps i have a second set i will ask tomorrow and send you a PM.
  11. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    Amazing, thanks, very much appreciated. I presume they fit GTC4L...????
    And Out of curiosity, why would you have spares?
    Sent from my BBB100-2 using Tapatalk
  12. -CD-
    -CD- F1 Rookie
    3,769
    Christian
    #63 -CD-, Aug 9, 2017
    Spares? You mean the second set? No not a spare part,
    a friend who works at Ferrari and brought me today a filter for the climate,
    told me that they should have a nos set which lays in their showcase and if i need again a set i should send him a message. :)
    And if they fit on the Lusso i will check tomorrow!
    I would say, yes!
    Seems to be enough space around the hole!
    On my Ex-FF they fit perfect, too. :)
  13. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    Very grateful, thank you very much!
  14. -CD-
    -CD- F1 Rookie
    3,769
    Christian
    You are welcome! :)
  15. -CD-
    -CD- F1 Rookie
    3,769
    Christian
    #66 -CD-, Aug 14, 2017
  16. omd78
    omd78 F1 World Champ
    Dec 26, 2005
    13,140
    Breda, Netherlands
    Martin
    Thanks for sharing Christian, congratulations on your new car! Wonderfull spec.
    Gr. Martin
  17. -CD-
    -CD- F1 Rookie
    3,769
    Christian
    Thanks Martin! :)
  18. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    Looks like lots of fun!
  19. Brian L
    Brian L Formula 3
    Jun 17, 2015
    1,943
    Los Angeles
    Brian
    Maybe next time, if you go in Sport mode you will save brakes AND learn the limits :) More fun
  20. Solid State
    Solid State F1 Veteran
    9,639
    Maximus Decimus Meridius
    If torque is specified with dry threads then would advise against adding lubrication. I'm assuming you are applying anti-seize to avoid dis-similar metal corrosion risk induced by changing the base metal to Ti. The stock steel OEM bolts have a surface treatment (black finish) to avoid long term corrosion and are much stronger. Weight is irrelevant with this vehicle but to each their own. Would definitely not apply lubricant to the collar/wheel contact area for any reason. Best.
  21. -CD-
    -CD- F1 Rookie
    3,769
    Christian
    Also Race didn't save brake pads very well... :)
    But you're right Wet is not the mode to go! :D
    First trip, first track drive, i felt good with Wet... :D
  22. -CD-
    -CD- F1 Rookie
    3,769
    Christian
    I was a little bit nervous but yes, it was big fun on the track! :)
    And the Oldtimer Grand Prix is always great!
  23. Caeruleus11
    Caeruleus11 F1 World Champ
    10,893
    #75 Caeruleus11, Aug 18, 2017
    Congratulations Christian! WOW!! That is a real beauty! I love your upgrades and attention to detail! I also love how your username is -CD- and in one of the pictures you are standing under a sign that reads "CD"
    I also love that you brought your wife and dog for the experience. You are a handsome family! :)
