frozen hood struts | FerrariChat
frozen hood struts
Discussion in '365 GT4 2+2/400/412' started by intrepidcva11, Oct 3, 2017.
  1. intrepidcva11
    intrepidcva11 F1 Rookie
    3,215
    Saratoga Springs NY
    Seth
    my new 1986 412 has arrived. Friend came to look, asked to see the engine, opened hood, he admired the lovely Colombo V-12, then I could not close hood, struts frozen and locked in raised position. HELP!
  2. Part Time
    Part Time Formula Junior
    494
    Port St. Lucie, Fl
    Gary Shore
    That's a new one.....if the gas cylinder is at the lower end, (attached to the car, not the hood), I would spray WD40 or the like where the shaft goes into the cylinder and let it sit for awhile. The only way to get enough pressure on them to collapse when stuck would be to remove them and cobble up a fencepost/lever setup to try to force them to close. There are several threads as to where to get replacements....just in case.
    Gary
  3. D.J
    D.J Karting
    Mar 17, 2015
    103
    Perth WA
    Unless someone has put locking struts in , the hatch on my esprit need to be lifted a little before the struts will allow the hood to come down.
