Fall '17 Stoogeapalooza | Page 3 | FerrariChat
Discussion in '348/355' started by TrojanFan, Aug 31, 2017.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    I am bringing bar stocks, 2 inch by 18 inch by 1/4 thick.... There is no other way.
  2. fatbillybob
    Aug 10, 2002
    26,294
    socal
    do you want me to bring a MIG welder? Maybe a 4" angle grinder will cut anything
  3. TrojanFan
    TrojanFan F1 Rookie
    Nov 17, 2008
    4,887
    So. CA & NV
    Peter
    I have 22ov in my garage from my electric car. I understand that there may be different types of 220 plugs. I can take a photo of what I have.
  4. TrojanFan
    TrojanFan F1 Rookie
    Nov 17, 2008
    4,887
    So. CA & NV
    Peter
    If anyone is thinking about doing an oil change, Walmart.com has Mobil 1 European for under $23 for a 5 qt jug.
  5. fatbillybob
    Aug 10, 2002
    26,294
    socal
  6. yelcab
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    Yes, Billybob, bring your MIG...and a grinder.
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,562
    SoCal LA/OC/New Mexico
    Tim Dee
    Yuup thats a Hobart plug they call it
    Have Peter post a pic of his outlet
    I have an extension about 50 ft if needed
  8. fatbillybob
    Aug 10, 2002
    26,294
    socal
    Yes Pete...Does it fit????
  9. TrojanFan
    TrojanFan F1 Rookie
    Nov 17, 2008
    4,887
    So. CA & NV
    Peter
    I'll take a photo when I get home. Some of us are at work.
    Still like the 612 timing belt change idea :)
  10. TrojanFan
    TrojanFan F1 Rookie
    Nov 17, 2008
    4,887
    So. CA & NV
    Peter
    Get your orders into Daniel at Ricambi for your parts if you are planning any work. I'm looking at the 612 Service Kit. $1,275 Ouch!
  11. Srtviper
    Srtviper Karting
    Sep 6, 2016
    90
    8. SRT Viper (tentative)
  12. fatbillybob
    Aug 10, 2002
    26,294
    socal
    Happy to help on the T belt but I don't think it is a one day stooge project. Also, ask Bruce about that bar. IIRC there is a bar that obstructs access and I don't remember what the solution was for it. It could have been take 1/2 the car apart to get to it. Like I said the ONLY chance of a lock and swap is if lots of stuff was off the car before we got there.
  13. TrojanFan
    TrojanFan F1 Rookie
    Nov 17, 2008
    4,887
    So. CA & NV
    Peter
    Car should be here a few days before the event so I'll take a look.
    As for the 220v plug, I have a different type.
  14. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,562
    Tim Dee
    Yeah Pete thats not something you want to rush. too many variables to "power stooge" it, even if we did the tag team cage match version of stooging
  15. TrojanFan
    TrojanFan F1 Rookie
    Nov 17, 2008
    4,887
    So. CA & NV
    Peter
    I do have one of the Harbor Freight welding set ups if that helps for anything. Won't be as clean of weld but it works.
  16. fatbillybob
    Aug 10, 2002
    26,294
    socal
    Mitchel....this is what we need to make my welder work. There may be cheaper conversions if you want to pursue this. 4 prong outlet just puts the ground and neutral on separate pins. Old school 3 prong plug joints the neutral and ground while the other pins are 110V each x 2 =220.
    https://jet.com/product/detail/b2dd7e268c4549779777faa2729fed4f?jcmp=pla:ggl:b_nj_dur_gen_tools_home_improvement_a1:tools_home_improvement_power_hand_tools_welding_soldering_a1:na:pLA_858550032_40236836621_pla-343847449580:na:na:na:2&code=PLA15&pid=kenshoo_int&c=858550032&is_retargeting=true&clickid=5109d410-848a-40e2-a0d2-45bb702b7b47
    Pete if you don't have a gas bottle for your welder then it is a fluxcore welder. If it is the HFT 110v welder that will work OK but not as clean as my 220V lincoln MIG with gas. I can still lay down a good weld bead with fluxcore. Fluxcore is basically stick and that is how all structural; steel buildings are made . So flux is fine.
    I leave it to mitchell to decide since it is his car.
  17. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,562
    Tim Dee
    Just get a male plug like that I have a 20 ft extension with proper female end we can put it on the end for the day. I think it's just called a 4 prong 50 amp outlet
    EDT
    I'm wrong its called a grounding stove outlet
  18. 16v2911TT
    16v2911TT Karting
    137
    LA
    1. TrojanFan
    2. Plugzit
    3. SoCal1
    4. Yelcab
    5. Mikster
    6. FBB
    7. Vince
    8. darkkaangel
    9. dfranzen bringing tri-tip!
    10. Formula1r bringing moonshine
    11. 16v2911tt - parking brake shoes, maybe steering wheel swap
  19. Formula1r
    Formula1r Formula Junior
    Feb 7, 2007
    458
    Los Angeles, CA
    Ross
    What time is the game?
  20. maxvonauto
    maxvonauto Karting
    159
    Corona
    Mark
    I've got a Mig (110 or 220), Inverter Tig (220), Plasma cutter (220), chop saw, drill press, grinders, compressor, measurement tools, just about anything to fabricate with steel or alum. No problem transporting in the back of my truck. Let me know. Mark.
    SoCal1 likes this.
  21. TrojanFan
    TrojanFan F1 Rookie
    Nov 17, 2008
    4,887
    So. CA & NV
    Peter
    Game time has not been set as of yet.
  22. TrojanFan
    TrojanFan F1 Rookie
    Nov 17, 2008
    4,887
    So. CA & NV
    Peter
    It's the HFT 110 V fluxcore.
  23. yelcab
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    All I will be doing it to weld a right angle plate to a 1/4 inch stock bar and welding a few bolts to the bar. I think the 110V flux core unit will be sufficient....
  24. TrojanFan
    TrojanFan F1 Rookie
    Nov 17, 2008
    4,887
    So. CA & NV
    Peter
    Vince:
    I have a small turkey but I don't think I will have time to roast it that morning. If you want to bring your deep fryer, I'll have the turkey ready to go. Otherwise it's a pass. There will be plenty of other food.
  25. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,562
    Tim Dee
    Image Unavailable, Please Login I'll bring something Peter
    May drive my subaru I sat in the 348 yesterday and needed the engine lift to get me out LOL, I''ll try again this weekend unless you guys can pull me out of the car? I'll keep the roof off for easy access
