F40 Seats | Page 2 | FerrariChat
F40 Seats
Discussion in '288GTO/F40/F50/Enzo/LaFerrari' started by Jati, Mar 26, 2008.
  1. Tipo815
    Tipo815 F1 Rookie
    Nov 1, 2003
    3,565
    Newport Beach, CA
    Jeffrey
    Joe - Might I suggest posting some photos of your existing seats including close up shots of the defective areas. For $12,000 I would imagine that someone would jump at your offer if they didn't think your seats were too bad/unrepairable.
  2. Tipo815
    Tipo815 F1 Rookie
    Nov 1, 2003
    3,565
    Newport Beach, CA
    Jeffrey
    They do not, however, no modifications are necessary. Nothing changes from OEM. You just need some OMP (or other) seat brackets that will screw into the existing holes. I actually had some aluminum plates made to raise the sit 1/2 inch higher and to move the seat brackets forward a little. You lose the slider option that the OEM seats have but I figured no one else is going to be driving me F40 so who cares if the seats are fixed. Fortunately, my Ferrari technician at Ferrari of Orange County was even shorter than I am and had no problem with my revised seat position.
  3. Jati
    Jati Formula Junior
    Dec 3, 2004
    299
    Florida & NC
    Joe G.
    #28 Jati, Apr 1, 2008
    Here is a pic of my seats in the car. The seats are faded more than the pic shows. There are some places on both seats where the foam beneath the nomex is losing its shape also...Tough to see from the picture, but look closely at the passenger seat thigh support, where the stitching is & you can see the padding in the rows is a bit dimpled. If you look closely at the side/upright of the drivers seat, one can see the slight stress lines associated with getting in and out of the seat....No cracks though.
    JG
  4. Tipo815
    Tipo815 F1 Rookie
    Nov 1, 2003
    3,565
    Newport Beach, CA
    Jeffrey
    Geez Joe. Those don't look too bad. I bet you could probably send the seats back to Ferrari's restoration department and they could restore them to brand new for you for less than $12,000 (or certainly no more than $12,000). They have a department that exclusively restores cars. I'm sure they could do the seats. My suggestion would be to contact Ferrari NA and make some inquiries. You could end up with "officially restored F40 seats" from Ferrari with supporting documentation! :)
  5. tx246
    tx246 F1 Veteran
    6,472
    Texas
    Shawn
    i understand the quest and cost for perfection. what is the best guess as to the "street" value to the seats that are currently in the car?
  6. mattymouse33
    mattymouse33 F1 Rookie
    Oct 25, 2004
    4,630
    We'll set aboot ye!
    Matthew
    Joe, you are a true perfectionist i see however i suppose these things have to be done to achieve a possible concours car. I would seriously investigate the re-trim by A N Other or the cost by Ferrari as to me you seem to be offering a fairly substantial amount for what looks like a fairly easy (ish) fix. Dont increase the bid anymore as I'm sure you'll find them with an offer like that!
    Regards,
    Matthew
