F12 in automatic | FerrariChat
F12 in automatic
Discussion in 'F12/812' started by Jeff Gilliam, Oct 6, 2017.
  1. Jeff Gilliam
    Jeff Gilliam Rookie
    Dec 25, 2016
    45
    I know I know I shouldn't be driving this car in automatic but from time to time I do. Just wondering if any of you are having issues with the transmission in automatic. Mine seems to stay in a high gear too long and in traffic from time to time it's not smooth at all. When I shift myself I don't have any issues. I only have 600 miles so far so maybe this works itself out.
  2. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    No sure about the F12, but at least the automatic works fine in the FF when one decides to not continue with spirited driving. What I still don't understand is this whole thing about "easy auto exit" and regular "auto."
  3. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    25,886
    DFW, Texas
    Tom C
    O...I think of you turn it off in manual, it turns back on in Easy Auto Exit mode, which then stays in manual the first time you use the paddles. In the regular Auto, it'll switch back to auto mode after a few seconds. If you turn car off in regular Auto mode, it'll be in that mode upon restart.
    OP... For what it's worth, my Cali is kind of clunky in auto mode, stop and start traffic. When it's down in the low gears. If I'm driving in Auto on the highway, it's smooth. In those cases, items usually in 6th or 7th...T
  4. Caeruleus11
    Caeruleus11 F1 World Champ
    10,893
    My F12 is similar that it will seek the highest possible gear when in auto mode. But I don think the shifts are too rough. I usually drive in manual as well, but if I encounter stop and go traffic I might pop it into auto mode.
  5. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    I will have to try that by pulling the paddle before turning off the engine next time to see if turns back on in Easy Auto Exit.
  6. MDEL
    MDEL F1 Rookie
    3,586
    Southern Europe
    Mario
    I also like to drive my F12 in manual and several weeks ago something happened that frightened the hell out of me and I'll mention it to you for a question of precaution. I was driving on a costal road with little traffic and when I got to a straight there were two cars in front of me and I prepared to overtake them. While I was overtaking the first one I see another car coming on the opposite direction and in order to overtake the second car faster, I pulled the left paddle to reduce one gear and accelerated. As soon as I did that the rear of F12 went right and left but fortunately I was able to recover the control and overtake the second car but 1 mile ahead I stopped a bit in shock and checked the tires to see if there was some problem. The tires looked perfect so I wondered what happened and didn't arrive to any conclusion. However some weeks later I was reading a post placed by Jerry ( Caerruleus11) about a similar situation and I started figuring out what could have happened. The ground around that road is sand and the tarmac also looked a bit polished and I think the combination of these two factors with the big torque increase of the F12 when I reduced one gear and accelerated nearly created the perfect storm. After that episode I've been much more careful about where I reduce gears and accelerate.
  7. italiafan
    italiafan F1 World Champ
    16,121
    Stickbones Swagglesmith
    When accelerating hard the back end of my F12 frequently squirms around, sometimes alarmingly. It also tram-lines like crazy so I chalk it up to huge torque and Pirelli with hair-trigger suspension and steering.
    The times I have driven in auto is because I have a phone call, or it is "date-night" and driving along with wife chatting away...in those circumstances it is usually light accelerator peddle pressure and casual driving in sport mode (essentially asking it to perform like a normal car)..auto function is smooth and flawless.
    Needless to say 98% of the time it is in race mode and manual! :D
  8. SVCalifornia
    SVCalifornia Formula 3
    2,449
    Silicon Valley
    Keith
    What tires do you have and what manettino setting were you in? Good observation on the road conditions, it may help to know the tires and setting...
    SV
  9. Solid State
    Solid State F1 Veteran
    9,636
    Maximus Decimus Meridius
    That's a scary story Mario but all too familiar. Never take the F12 for granted. I have learned to respect the drivetrain by driving more and more in ESC OFF when in ideal country road conditions and no traffic. I find in the other modes the rear brakes drag to provide the traction control and other supervisory functions. With all aids turned off you must be careful 100% of the time and you get a great feel for the power/traction relationship. Not advisable in traffic or in poor road conditions. Relying too much on the nannies can get the F12 to swap lanes instantly with bad results.
  10. phanliu
    phanliu Formula Junior
    622
    Illinois
    Noel
    Plain physics - too much torque at once for only the rear wheels.
  11. MDEL
    MDEL F1 Rookie
    3,586
    Southern Europe
    Mario
    The tires are the Pirelli's PO and the manettino setting was Sport when that happened.
  12. MDEL
    MDEL F1 Rookie
    3,586
    Southern Europe
    Mario
    Driving with the manettino in ESC OFF is something I haven't done on the road yet. As you say and I agree it's a very straight forward way of one being aware of what the F12 is capable and probably the best precaution medicine we can take.
  13. Caeruleus11
    10,893
    Mario, very scary. Sorry that happened! I find in the US on most roads in clear and warm temps (above 65F) I can accelerate without much worry. Sometimes this is the system helping out- I can feel it apportioning torque side to side via the e-diff and F1 Trac software. I think this is one of the great abilities of the F12- its useable in real world conditions. Such is the traction. I think if the road material crates less friction where you are, then you have to be more careful. Also, I think the P-Zero generation on the F12 is not as good as the Michelin Pilot Super Sport. Some people prefer Pirelli tires, but in general I prefer Michelin. I think you might find some more traction with the Michelin tires as well- though if you can wait I would see about the new MP4S (or whatever its called- the successor to the MPSS). An high end installer shop I frequent had a set of these tires, brand new, next to a new set of Pilot Super Sport tires- and this is very unscientific, but they just felt so much stickier!
    To come back to the topic of the thread, I had my car in traffic in auto the other day and it behaved just fine. No problems at all.
  14. MDEL
    MDEL F1 Rookie
    3,586
    Southern Europe
    Mario
    Jerry I'm really thinking of changing the Pirelli's PO by the Michelin's PSS. Recently enquired about the PSS 4S and was told they not available yet and they don't know when they'll be. I wonder if it's worth waiting.
  15. Caeruleus11
    10,893
    I think then its not worth waiting because who knows how long it will take and the MPSS are very very good. They really helped my 599.
  16. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Mar 18, 2014
    3,778
    Europe, but not by much.
    Nuno
    Mário,
    First of all I'm glad you are OK and it was nothing but a scary moment.
    I strongly advise against using auto mode, except in some city traffic circumstances. Kickdown is OK but not the same as if I was physically operating the paddles, and I always feel less connected with the car whenever I'm not in manual mode. Downshifting in auto is less intuitive, in my humble opinion.
    Regarding tyres: Pirelli seem less grippy in general and noisier. In my opinion, they give a harder, stiffer feel. A more "woody" feel. Michelins are wonderful, but wear off quickly (a consequence of being wonderful!). I recommend the Michelins if available, they're worth it. The best tyre I've ever had in a sportscar (have them in my 355 and 458).
    Kind regards,
    Nuno.
    Caeruleus11 and MDEL like this.
  17. MDEL
    MDEL F1 Rookie
    3,586
    Southern Europe
    Mario
    Nuno, nice to see you around and I'm glad you're fine.
    I agree with you regarding the Pirellis and after receiving advice from other F12 owners I'm seriously thinking of changing them soon by the Michelins PSS. I had the Michelins in my previous Ferrari and I really loved them.
    Take good care and I look forward the opportunity of hearing your white polar bear.
    Regards
    Mario
    AlfistaPortoghese likes this.
  18. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    There is also the new successor, Michelin PS4S but still no sizes available for this car yet.
  19. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    I thought PSS would last longer than P0 due to PSS having higher wear rating.
  20. Caeruleus11
    10,893
    I agree - it feels to me that Michelin have softer feeling sidewalls and Pirelli have harder feeling side walls. I like how the Michelin feel better and if that means I have to replace the tires a little more frequently, then I am prepared to do it.
  21. deltona
    deltona Formula 3
    Aug 7, 2009
    1,386
    Justin
    Hi Mario.
    I had Pirelli on my FF but specified MPSS2 on my F12. They are a great tyre and I would highly recommend them. I am surprised that even at the low morning temperatures we get in the UK I've had issues at all yet.
    The best way a can describe them is that they feel like they grip at lower temperatures whereas the Pirelli just feels like it's sitting on the road, not gripping it.
    I avoid using the auto on mine. I think the upchanges are far to early and presume they have been set thus way to help fuel consumption fighters to keep the bureaucrats happy. ;-)
  22. MDEL
    MDEL F1 Rookie
    3,586
    Southern Europe
    Mario
    Justin thank you for your advice on the tires. I've already taken the decision and despite of the fact the Pirellis are almost new, I'll change them for the Michelin PSS.
    deltona likes this.
  23. Caeruleus11
    10,893
    I think you will really like the change Mario. Maybe you can sell the Pirellis? Or find a Ferrari friend who needs them?
    MDEL likes this.
  24. MDEL
    MDEL F1 Rookie
    3,586
    Southern Europe
    Mario
    Jerry thank you for the advice on the Michelins PSS. what I'll probably do with the Pirellis is to keep them and if one day in the future I decide to do a track day I'll use them.
  25. Caeruleus11
    10,893
    That sounds like fun!
    And to keep to the thread topic, I suggest you not use the automatic mode on the track :)
