Early Ferrari 355 CAM Cover, P/N 154653 | FerrariChat
Discussion in 'Parts & Collectibles' started by Dave rocks, Apr 18, 2017.
  1. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    #1 Dave rocks, Apr 18, 2017
    Hello Folks,
    I'm looking for an early 95 355, right hand CAM cover P/N: 154653.
    I need a non-damaged cover, it will be painted so I don't care if the finish is bad. I need something that is not broken, cracked or warped - sealing surfaces must be good.
    This is for an early 355 in which the spark plug cover has only 4 screws for fastening.
    The attached photo is an example.
    Thank you.
    Dave Lelonek
    dave.lelonek@**********.com
    716-553-6130
  2. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    To clarify as some have asked - this cover only have 4 screw holes for the plug cover. That's the one I need (early cover)
    Thanks.
  3. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Still looking. Let me know if you have one :)
  4. 97 Spider
    97 Spider Formula 3
    2,241
    Texas
    Brian
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
  6. 97 Spider
    97 Spider Formula 3
    2,241
    Texas
    Brian
    Ok, just wanted to make sure you’d seen it. I’ve bought a few items from them in the past and didn’t have any trouble.
  7. 97 Spider
    97 Spider Formula 3
    2,241
    Texas
    Brian
    How much are you looking to spend on a guaranteed good one? You can PM me.
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Brian - I appreciate you looking out - thank you. My guess is it may have been a language barrier with that company. What's weird is some of there prices are good while others are out to lunch - higher than new OEM. I found a set of covers with the more holes and I think I paid $400 for the set of 2. I'm just trying to keep my car original.
  9. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,488
    Lake Villa IL
    I forgot Dave, what's wrong with the one you have? Nothing welding/machining could fix?
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hey Jim - It's been welded (by someone else in the past) and it's not great. IIRC, the gasket surface is not flat (possible warped from the welding heat).
  11. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,488
    Lake Villa IL
    Well if you get desperate could probably weld a bead all the way around and machine it back flat.
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Jim - I found a set of covers with the 10 or 11 screw holes - so I can use those. Just still looking for another should one come around ;)
