Does the 360 spider top lower tray pre fuel pump acces and access panel part fit all the same | FerrariChat
Discussion in 'Technical Q&A' started by knocker, Sep 21, 2017.
  1. knocker
    knocker F1 World Champ
    11,783
    Sydney Aus
    Adrian
    Q -as we know in 2001 the acces panel for fuel pumps upgrade happened on the spider but are they the same fit has anyone successfully replaced one for another plain common sense if I have the roof out for a job
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,344
    The Cold North
    Tom
    First off..you do not have to remove the roof to do this job. The tub will come out with the roof still in the car. I have done it many many times. It is a bit time consuming, but much better then messing with adjustments afterwords. If I'm reading your question right, you want to replace the tub with a later version for access..yes you can do that without issue.
