Derek's 308 engine rebuild | Page 16 | FerrariChat
Discussion in '308/328' started by derekw, Oct 16, 2016.
  1. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    The end mill on my drill press to deepen the valve pockets was a crap idea. It would bite and release, bite and release, so very hard to control. I found a mini router with a grinding stone followed by a drum sander on my Dremel tool worked best. I must have done 8-10 test assemblies with playdoh, heads, cams, belts to get all the clearances where I wanted them. I also did the squish landings to get .050 with piston rock. A bit less would have been better but the compression of the head gaskets over time and retorques, liner movement, etc. made me a bit conservative.
  2. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    #377 derekw, Aug 16, 2017
    We retorqued the heads this morning and will now test for leaks. Fingers crossed! We put a very thin smear of copper Permatex around both sides of the holes which had no sealing rings. Should work well... says he hopefully. I need to take the cars to Montreal tomorrow and Friday. Dead Forest Motors is shutting shop and moving on to wetter climes.
  3. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,086
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Best wishes to you, family and cars on this next leg of your great adventure.
  4. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    Just a quick update to say my cars arrived safely in the UK and are now stored in Surrey. I plan to go down now and then to slowly get the 308 put back together. The storage looks rough but is sealed, dry, and secure (being in someone's back yard.)
    On a sadder note, my erstwhile assistant Matt Maggio-Tremblay is either unable to answer his phone or email (I hope he is ok), or he has decided to keep my roof spoiler that he said he would drop at the shipper (and my Image Unavailable, Please Login Image Unavailable, Please Login ´61 Jaguar Mk 2, heads, carbs.) If anyone sees either for sale in the US or Canada, please let me know.
  5. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,166
    Gold Coast, Aust.
    Patrick
    That is sad. The world is a very small place nowadays - I'm sure that pressure can be brought to bear. On a lighter note, if it gets done by xmas, I will substitute the Moosehead with Dog Bolter Real Ale
  6. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    Just an update to let anyone following this tome that Matt did get in touch in December and I was able to get my parts back this summer.
    One of the funnier things that happened to us in those last couple of days in the dead forest garage was pressure testing the water system before we closed up the engine and mounted it onto the transaxle. We blocked all the other inlets/outlets, clamped a length of water hose to the thermostat housing, plugged it with the end of a rubber mallet that fit well, tightened the clamp, filled the engine with water and then pressurized it to about 15psi for 30 minutes. One tiny leak on the one inlet manifold so we disconnected the pressure, loosened and evenly re-torqued the manifold nuts and re-tested for an hour. No leaks. Bumped up the pressure to 20psi and the mallet head plug shot across the garage with a helluva bang, narrowly missing Matt!
    Milkshaker0007 likes this.
  7. Ferraridoc
    Jun 20, 2012
    16,166
    Gold Coast, Aust.
    Patrick
    Do you know what this means? You owe me a carton!!! Merry Christmas, Derek!
  8. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    ... I've been half expecting that for a while. They have pretty good beer here in Pommiland if you ever make it over :)
  9. Ferraridoc
    Jun 20, 2012
    16,166
    Gold Coast, Aust.
    Patrick
    Maybe next year. At the moment, I'm so busy, I have to book a half an hour two weeks from Tuesday just to scratch my arse :eek:
  10. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    While sorting boxes (now that my torn shoulder ligaments are a bit better) I came across my alternator so decided to pull it apart as it wasn't turning smoothly and looked very grimy inside. I found this good post from jmaienza which helped: https://www.ferrarichat.com/forum/threads/bosch-alternator-disassembly.343680/
    Using a thick flat screwdriver and some penetrant I got the 4 long screws to move after a few light taps with an impact screwdriver. Once they were out, I supported the two front mounting lugs on the two sides of a vice and tapped down on the back casing with a wooden drift and a plastic mallet. Careful when it comes apart as the stator ring (red oxide coloured) must go down and off with the back casing. If not you can damage the wires connecting the stator ring to the diode plate.
    Once the back casing is off you can hold the rotor (wrapped in cardboard) in a vice and remove the big nut on the fan, then take out the 4 screws behind the fan, rest the front casing lugs on the vice jaws and tap the shaft down and out of the casing with a plastic mallet. Three screws hidden on the diode plate come out to allow the diode plate and stator to be separated from the back case. It was really dirty and had lots of oxide inside.
    My bigger (front) bearing was very good (type 6303ZS) but my smaller back bearing (6201C3) was not very smooth so I got a long, flat punch behind it and tapped it off. I then held the bigger bearing (gently) in a vice with the rotor vertically above it and pointing up. I put a drill onto the other end so I could spin the rotor to polish the slip rings (fine sandpaper, then scotch pad.). I also used some medium sandpaper on the outside of the rotor which had some surface rust. I'll paint the rotor with some rust converter paint.
    To clean the very dirty housings (forty years of oil, grime, some oxide), I put a dish washing tablet into half a bucket of very hot water and let them soak for an hour, then used a nylon dish brush, and finally a brass brush. Took about 10 minutes of brushing and worked like a charm. I cleaned the diode and stator ring with a dry brush and compressed air then tested the diodes. Put one multimeter lead onto a stator wire where it is soldered underneath the negative plate and then check continuity to the negative plate above and then to the positive plate next door (with the long, threaded positive power output.) On one plate should have a low resistance and on the other no flow (open circuit.) Then test the other two stator wires in the same way. All good.
    My brushes were down to 12mm long so I ordered some new ones (8mm x 5mm x 19mm.) If they are too long I'll file them shorter. £6 on ebay. I also ordered a new SKF bearing for the back with two seals and high temp grease (6201 2Z/C3HT51 for only £3 from georgelodgedirect.co.uk.) On a roll I ordered some red oxide enamel for the stator from ebay. When I get the parts I'll report on the brush change and reassembly.
    View attachment 2601722 Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  11. marklintott
    marklintott Formula Junior
    579
    Taipei Taiwan / Somerset UK
    Mark Lintott
    Your description and the linked post are the best I've seen on this - thank you. I ended up getting a rebuilt unit from ebay as at the time I wasn't sure what I was getting into once or if I managed to get the long bolts removed. Some ali/steel corrosion in evidence.
    Anyway, I have an old one needing re-furb if anyone is interested....
    Mark
  12. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    I decided to order the big bearing too, a Timken 6303 2Z/C3 from George Lodge for £3. Probably not needed but "while it's apart..." I forgot to mention checking the rotor coil continuity test (I got 3.5 ohms between the slip rings.) Also test for short circuits on the rotor and stator. There should be no flow from the slip rings to the rotor shaft or poles or from the three stator coil ends to the iron stator ring.
  13. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    The bearings just arrived today which reminded me to post a description and some pictures of the alternator going back together. Putting the new brushes into the housing was straightforward. Use a soldiering iron to de-solder the wires, lift the tabs clamping the wires at the back, pull the brushes out, fit the springs on to the new brushes, feed the wires through into the housing, trim the insulation sleeve, solder the wires on and clamp them with the tabs, and then trim excess copper wire.
    I sprayed the field coils and rotor with high temperature clear varnish once they had been cleaned and the rotor painted with rust converter. The high temp varnish is probably not needed but I thought a little extra insulation can’t hurt. I also sprayed the iron field coil ring with the red oxide enamel. I’ll go and press on the new bearings and take some photos of the alternator going back together. Before you put the field coil back into the rear housing, check that the three field wires are not touching the bunches of windings (they could rub and wear through) and also not sticking out too far so that they rub on the housing. Once I had put mine into the rear housing and screwed in the 3 screws, I noticed one field wire touching one of the diode plates so i used my finger to lift it away a couple of mm. Again, it could rub through the insulation sleeve and short.
  14. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    #389 derekw, Sep 29, 2018
    Removing the larger front bearing was a little tricky since I don’t have a thin bearing puller. I supported the bearing seal plate with two thin spanners (wrenches) across the vice jaws, put the four screws in to protect the threaded holes, filled any gaps with washers, and then tapped down hard with a flat steel punch. Nothing! After heating up the retaining collar with a heat gun it moved and after a few millimetres I was able to fit my bearing puller behind the plate and remove the collar, bearing, and plate.
    The new bearings tapped into place without any problems. I found a 12 mm socket which fit the inner race of the small bearing and a spark plug socket that fit the inner race of the big bearing (and then collar.) Remember to put the plate on first with the concave side facing forwards.
    Two things to remember are the white insulator sleeve into the rear housing for the long threaded power output rod (before you put in the field windings and diode plate assembly) and then the wave spring which goes into the back housing bearing recess before the two halves go together.
    To hold the brushes in the retracted position for insertion, I used two match sticks hooked behind the wires (see pic) and was then able to fit them into the back housing. Re-assembly was quite easy and only took about 10 minutes. Remember to tighten the fan nut before you put the two housings together so that you can hold the rotor while tightening the nut. I used blue Loctite just for insurance and also to reduce galvanic corrosion on the long screws. I'll phone around to see if anyone can test it for me before I fit it.
    Milkshaker0007, thorn and waymar like this.
  15. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Those stator windings look brand new. How'd you get them so clean? (I see you said a dry brush and air, but dude... stellar results.)
  16. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    Coat of high temp varnish makes them nice and shiny!
  17. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    So I managed to get some parts off the 308 to work on at home-- brakes, front suspension, and the original magnesium wheels. First job was to rebuild the calipers and even though I plan to use Wilwood calipers up front (inside both 14" and 17" wheels) I am rebuilding all four.
    Starting with the front calipers, ATE 48mm 2-pots, same as early Porsches, I battled to get the pistons out despite lots of penetrating oil, heat gun, levering etc. Normally I'd just pump them out with the brake system but the car is an hour away so I skeptically tried a bike pump and it worked! Once one was out I put it back in a bit, clamped it and pumped out the other one. The hollow threaded tube from a light fitting fitted the brake inlet nicely.
    Bigg Red on ebay.co.uk has all four front 48mm pistons/seals for £40 (part No. BRKP86.) I first bought the seals from buycarparts.co.uk (autodoc.de) for £5 each side (248030) but I got the kit with pistons as I had damaged the piston lips trying to lever them out.
    The original finish was clearly silver plating and in a few places there was surface rust so after a good clean with a wire brush, strong alkaline wheel cleaner, and a pressure washer, I dried them in a warm oven and then painted on a thin coat of rust converter just to stop any further corrosion. I cleaned the bores with green scotch pad, cleaned the bores and passages with brake cleaner, dried it with a hair dryer, lubed bores and pistons with brake grease, put in the new seals, and assembled them using the good info on the Pelican Parts forum:
    https://www.pelicanparts.com/techarticles/911_caliper_rebuild/911_caliper_rebuild.htm
    It's important that the cut-out section of the piston faces into the oncoming brake disk's rotation. This increases the clamping force on the trailing edge of the brake pad which makes the pad wear more evenly and reduces squealing. A simple rule for the 308 calipers is that the middle of the raised ridge points towards the bleed nipple on both calipers and the end of the raised ridge that is closer to the wheel axis is in the center (i.e. in line with the brake inlet or between the mount bolts-- see my pics below.)
    sltillim likes this.
  18. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    I have been waiting for two weeks for a warm day in London to paint the original magnesium wheels but eventually gave up and have cranked up the heat in our one bathroom. The chromate paint is nasty stuff so I got the wheels nice and warm, ran outside to spray one, brought it back in to dry.
    The real work was the 4-5 hours of cleaning, brushing, wire brushing, acid cleaning, brushing, neutralising, cleaning... I first used a pressure washer and then a good scrub with an alkaline wheel cleaner. Once the dirt was off I cleaned off the oxide where the wheels had scratches or the paint had come off using a 12% acetic acid that every proper Swedish home has (Ättik Sprit.) You can see the metal and oxide bubbling and coming off. A stainless steel wire brush helps break it free. Then an alkaline rinse to neutralise the acid (teaspoon of drain cleaner in a few litres of warm water (wear gloves.) There were black bits in the pitted surfaces-- either slag from the casting or some oxide reacting to the chemistry but they came out with more brushing and a sharp knife-tip. The inside diameters that sit on the hubs were the worst corroded and took a lot of brushing plus acid to clean up.
    Once the bad bits were properly cleaned and neutralised, I put a good key into all the surfaces for the new paint to stick. Lots of elbow grease and green scotch pads. Final clean and then a couple of days in the hot bathroom to fully dry. I've now done 2 coats where needed of Cessna Green chromate primer and was lucky to find some (bought 6 cans just in case.) It is no longer being made (try LAS Aerospace, about £6/can.) I'll let it dry for at least a day and then fill the blemishes and do the silver + clearcoat.
    Pero, 911308 and Saabguy like this.
  19. Einsteiger
    Einsteiger Karting
    Oct 9, 2014
    125
    Overland Park, KS US
    Kevin
    Incredible amount of work. Well done!
  20. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    These wheels are turning into the pit of despair, cough, cough. With the nice smooth mat primer on them, I noticed quite a few small bumps and digging through the layers I found a few more areas of black oxide lurking plus a few of the bumps were casting anomalies (perhaps sand cast?) So a lot more scraping sanding, brushing, acid, alkali, rinse dry... I'm only concerned about where there is corrosion hiding as anything that has survived 40 years without issues should be left alone.
    At least the weather is nice and warm now so I can work outside :)
  21. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    I changed the seals in my rear calipers and found some stainless adjuster plugs for the inside to replace the aluminium ones that had frozen and rounded the sockets.
    I followed Birdman’s article except that I did not split the calipers as they were not leaking (yet.) the pistons were in good shape so just cleaned everything up with brake cleaner, scotch pad polish of the pistons, and reassembled with brake grease and the new seals.
    http://www.birdman308.com/service/caliperrebuild/index.html
    To get the pistons out turn the outside adjuster anti-clockwise and the inner adjuster clockwise (same directions for tightening the hand brake.)
    As mentioned above, I got the seal kits from autodoc for about £5. Thorn suggested this amazon source for the plugs in the US: https://www.amazon.com/gp/product/B0786KY464
    But I got some plugs in the UK for £5 each (bought ten of them in case anyone wants some.) Look for M10-1.0 plugs.
    I got some Mintex M 1144 pads from eBay for £48.
  22. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    In between working on the wheels, I have cleaned up, painted and pressed in new bushes into the A-arms. I used the same Superformance original style rubber bushes that we used in the rear A-arms. Ground off the welds with a Dremel wheel, hot air gun and penetrant, dead bow hammer and a vice to get them out, then a vice and a suitable socket to press them in. My 32mm socket was not quite deep enough so I used one of the thicker spacers to add some space for the new bush to come into (rear bush of the front upper a-arm, not the front bush as I have said elsewhere.) A couple of the old bushes needed a bit more heat and penetrant but they came out without too much trouble. You have to get all of the old welds off as any raised bits will not allow them to slide out.
    I read elsewhere in the forum that you don't need to tack them in place but thanks to Brian H. for kindly correcting me, I will definitely tack weld them as the torsional forces from the design could cause them to move (the rubber acts as a torsion spring.)
    Brian Harper and 308GTB77 like this.
  23. dflett
    dflett Formula 3
    Jun 24, 2005
    1,603
    NY
    David
    I like the vice and socket method too rather than a hydraulic press. I think it’s a lot safer for the suspension arm. It’s very easy to feel if you are putting to much force in with a vice if something is slightly awry.
    When it goes in or out square, very little force is actually needed in my experience. If it’s proving difficult, time to check everything in case something is wrong. When I did mine I had to stretch one rear arm a little because it had been pressed in little too much and distorted by a previous install.
  24. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    As some of you will have seen in a question I asked about alternative brake disks (rotors), I am trying to upgrade my brakes while I have them out and apart. My goal is a setup that is inexpensive, better braking for track days, and can be easily put back inside the 14" wheels with original disks when needed.
    The Wilwood forged narrow Dynalites (120-15255, $108 from Sports Compact Warehouse) have 7% more piston area and a much bigger pad (I bought the Hawk fast road pads to try) and best of all the Wilwoods have the 3.5" mounting holes so fit well as a direct replacement for the ATE 2-pot iron calipers (see 3rd pic down on the left.) The best disks I could find widely available and inexpensive are the 298mm diameter, 24mm thick Porsche Boxter/Cayman front disks (Porsche 98735140101-left and ...201-right.) The Boxter/Cayman is about the same weight as the 308 and comes stock with bigger, stickier 17-19” tyres so should manage the 225/245 road legal tyres I’ll probably use. The disks are light at 6.5kg and I found left and right original Porsche disks separately on ebay for £40each. The Brembo disks (part 09.C090.11) are £57ea at design911.co.uk. The disks just fit inside the back plates as seen in the first photo and both the Boxter and the BMW disks have lots of space inside my 17” wheels so should fit 16” wheels as well (top left photos.)
    There are performance aftermarket cross drilled disks for all the other disk types that were a possible fit (BMW F20, F30, E81, E87, Mazda RX7 III, and a few others) but they were either too heavy or would need disk spacers to fit well. Plus they don't have the karma benefits of putting a P part on an F car . The BMW F20 front disks (312mm diameter) are a very good and easy fit but they weigh 8.8 kgs and I don’t like the idea of dragging around all that extra unsprung weight. (second two pictures.)[​IMG]
    I might do the same setup at the back using either the Wilwood 120-11578 (11% more piston area) or just use the standard 38mm ATE rear calipers on the Boxter disks so as to have a "functioning" handbrake. I had to order 10 of the front brackets in 7075 and matching hub rings in case anyone else wants to go this route.
  25. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    Anyone needing Wilwood calipers, pads etc. Today only! Sports Compact Warehouse have 10% off today only with code April10. They have lots of other car stuff too.
