Best and Most Accurate Tire Gauge | FerrariChat
Discussion in 'Technical Q&A' started by 2COOOL, Sep 26, 2017.
  1. 2COOOL
    2COOOL Karting
    Nov 23, 2003
    91
    All:
    I'm in the "hunt" for the most accurate and best value quality tire gauge. Has anyone researched and identified, as well as purchased a tire gauge that is very accurate?
    I do care to have the tires inflated to an accurate pressure. Recently I found my gauges off significantly and was shock.
    All replies welcome.....
  2. IanC
    IanC Rookie
    Sep 17, 2004
    23
    Massachusetts
  3. tazandjan
    38,075
    Affirmative, I have two Longacres and they are excellent.
  4. Jeff328
    Jeff328 Formula 3
    2,293
    WI
  5. f355spider
    f355spider F1 World Champ
    17,940
    Consumer Reports actually tests them against a calibrated gauge...I can check and see who they recommend...
  6. f355spider
    17,940
    #6 f355spider, Oct 3, 2017
    Here you go, top 2 were from the same manufacturer:
    Accutire MS-4021B
    Accutire MS-4400B (note that reviews (by actual users) on this one were negative on durability))
    if you want analog, this was only slightly lower rated, but top of the dial type gauges:
    Intercomp 360060
    I personally use a dial type as the digital gauges don't have a very good reputation for durability. (the Longacre being the exception)
