458/488 Spider Side Glass Cleaning
Discussion in 'Detailing & Showroom' started by PA Wolfpacker, Sep 26, 2017.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. PA Wolfpacker
    PA Wolfpacker Formula Junior
    Aug 19, 2007
    276
    Naples, FL
    Neil
    Does anyone have a suggestion on how to keep the lower part of the side glass clean on the 458/488 Spider?
    Every time I clean the glass it looks good, but once you open the door the glass drops and once it returns to the normal level a smudge is left on the glass. It is worse when you drop the top because a larger smudge covers all the way to the top of the glass once returned.
    TIA for your help.
  2. JoshVette
    JoshVette Formula Junior
    Aug 12, 2007
    681
    Grand Prairie/Dallas
    Josh
    Clean it well, then put it back in the garage and clean it again after you close the door then let it sit overnight before you drive it again.
  3. woody byrd
    woody byrd Formula Junior
    334
    cary, nc
    woody byrd
    It drives me crazy. Brand new beautiful car, with grease marks at every point the glass stopped at. You can clean it fifty times, and it will return fifty times. I think next time I go to the dealer, I will make a point of lowering the window about one inch at a time until I have twenty grease lines on the glass. I keep thinking if I clean it long enough it will finally wear off, but not yet.
  4. Esoteric Auto Detail
    Esoteric Auto Detail Formula Junior
    Sponsor
    Dec 14, 2008
    800
    Columbus, OH
    Definitely a frustrating area! There isn't a whole lot you can do aside from regular cleaning. You could try a window coating to help make cleaning easier.
    GYEON View or POLISHANGEL Diver would be my recommendations...
    -- Ryan at ESOTERIC
  5. KM1959
    KM1959 Formula Junior
    928
    Kevin
    Sounds like there's some sort of contamination on the inside of the door glass wiper. Maybe lower the glass all the way and clean the insideF section that touches the glass? Just be careful as I've had some cleaners actually etch/stain the glass. I would think that diswashing soap would work.
    If it persists just think to yourself "F-it, I have a badass Ferrari".
  6. Roadking
    Roadking Karting
    Oct 9, 2005
    108
    I believe the factory puts a dressing on all door and roof rubber to eliminate squeaking. My California T and 488 Spider both have window streaking issues no matter how often I clean them. I noticed a similar oily film on the rubber over the windshield on both cars. It streaked the windshield until I was able to completely wipe it off. Getting inside the door rubber will be a more difficult proposition. I can't imagine the dealers haven't come up with a solution. It's unacceptable to have any new car that you can't keep clean, much less a Ferrari.
  7. Tired of seeing this ad? Upgrade now
