Thanks guys. I've heard the Hill bearings are actually better than the OEM Ferrari bearings since the former are real SKF and the latter may not always be. Is that true? Does anyone have an SKF bearing they could read the part number(s) off of? I have access to pretty much any SKF bearing, I just need the part number. Using 171057 hasn't been able to get that for me. I just want the best bearing from a good source. If I can get the SKF PN I can see if there's something even better.
I also changed mine with the Hill Engineering one. Look at that link for the picture of mine https://www.theferrarista.com/forum-ferrari/topic/4992-456m-changement-des-guides-de-soupape/?do=findComment&comment=221425 The bearing is For the accessory belt bearing look at: https://www.theferrarista.com/forum-ferrari/topic/4992-456m-changement-des-guides-de-soupape/?do=findComment&comment=221424 Sorry for the links in French.
Thanks. I ordered the Hill bearings directly from them and found a good source for the Dayco belts too. I still have a hard time believing that a car with less than 18k miles needs new belts and bearings. These cars had to comply with US emission laws which mandate that major emission control equipment has to effectively last the "useful life" of the vehicle. I believe this was 90k mi. in 2003. Now it's 120k for most cars and 150k for the cleanest ones. Even the maintenance schedule in the manual doesn't call for such frequent replacements. I know I have the "5 year" belts but even that's not very long for most timing belts. I will be driving the car at least once every 2 weeks, until it's fully warm. Even in the winter I'll move it around in the garage and let it get fully warm. That should eliminate a lot of the problems associated with letting it sit for too long. I don't plan on tracking the car but I will drive it like it was meant to be driven. Does anybody have any experience/comments on how this type of use would affect maintenance and replacement schedules? Or is it really just 5 years, ??? miles, or else? Thanks.
I think you're delving into a technical discussion which really isn't the purpose of this thread (interchanges). You should start your own thread or search the forums for answers. Not trying to be rude, just trying to keep this particular thread clean.
That question is the subject of dozens, if not hundreds, of threads. Do a search. Service items like belts do no have to meet the requirements you quote. Ferrari originally thought they did and had extended intervals for belt replacement that resulted in quite a few trashed engines. All the bulletins on cambelt changes are posted in multiple locations. Once you read those, you can use whatever change interval makes you comfortable.
Sorry for getting too deep into it here, should've moved the reply elsewhere. I've done searches and have found there to be a lot of conflicting information. I also wanted to get more current info to allow for changing technology, etc. Belts usually last longer.
One day I jumped into my 550 which started up ok but then had heavy steering Turns out that the alternator was failing so the voltage was low and as a result this steering unit didn't work properly. Took a while to figure it out but it became clear when instruments stopped working etc. changed alternator and added a new battery and all gremlins went away. Love how temperamental these cars are when it comes to voltage.
I came across an interesting claim today: the 456GT MAF is the same as that from a Saab 9000 or Volvo 740 or 960. I can't confirm, but the Bosch numbers match.
Good morning, Does anyone know the current part numbers for the 456M fuel pump and injector relays? I have been through a long and arduous paper trail with many replacement advisories. I am currently at Bosch #0 332 209 151. Thanks in advance, Dennis
Center Console strut 456GT (Stabilus are available but old stock and are usually dead) Associated Spring GSWB-4106-11
Andrew I had mine rebuilt as the stock of these have dried up Do a search of this thread it may assist.
Référence Ferrari part # 153095 Windshield Wiper Relay (intermitter) valid for the following models : 360/360 F1 Modena, 456 GT, 456 GT Auto, 456 GT/GTA, 456 MGT/MGTA (def) 1998, 550 Maranello, F355 ABS BOSCH/355 F1, F355 B/GTS/Spider Mo. 2.7, F355 B/GTS/Spider Mo. 5.2 BOSCH 1 147 328 143 (1147328143)
Go to Polar Bear in Ft Lauderdale. They can rebuild at a great price. I had one supplied by them, shipped overnight for under $500 cdn, but I had to swap the pulley over as they could not supply with a 6 groove, only an 8 groove. Scott
McMaster-Carr part # 9263k316 Viton O-ring 38mm id X 3mm wide stands more proud than OEM O-ring made of viton max temp handling 400 degrees F Image Unavailable, Please Login
accumulators interchangeable with bmw http://www.ferrarichat.com/forum/456-550-575-sponsored-bradan/344520-456-suspension-fix-what-difference.html
456 (same 355 and others): The headlights are produced by Hella. You can get them (without Ferrari-Logo) at the local dealer. Be aware that they come with 24V bulbs as they are used in MAN trucks nowadays. Left: 1DL 005 600-097 Right: 1DL 005 600-107 They are equipped with H1 bulbs for low beam and high beam, not the HB4 used in the original US-cars! Image Unavailable, Please Login
For those with dome light issue or window issues. The door stricker controls the widow and is sold as a complete set with a micro switch its from a bmw e36 The micro switch for the dome or door light is from an e36 coupe or cabriolet with the following part no: (L) Door Microswitch Assembly, p/n 51 21 8 208 423, $39.06 list, or (R) Door Microswitch Assembly, p/n 51 21 8 208 424, $39.06 list The installing/removal information is from: Frankie's BMW :: 3 Series :: DIY Procedures :: Door Microswitch Replacement
Has anyone come up with a replacement for the wheel bearing/hub on the 456? Apparently they are the same as a 355, 348 and 550.
If it is the same as a 355 then you wont find an alternative. The bearing is integral to the assembly not a stand alone item, the bearing outer race is actually the surface of the hub, its therefore unique to Ferrari. I stripped one hoping to replace the bearing with an off the shelf standard unit, it cannot be done I am afraid. They carried on the design with the 599 as we had a used one sent to us by accident, it looks the same but when we went to fit it then its a bit chunkier
Thank you all subscribers sharing this important parts information. Heater valve is no longer stocked and very difficult to refurb. Results in steady temperature build up without respite. Solenoid actuated valve sits in engine bay below the windscreen. Item 22 on the drawings at Eurospares: '22 electro magnetic valve'. Heater Valve Bosch 1147 412 013 Rardley Motors in UK thinks a driver has replaced with a BMW part but we have not identified. eBay and google searches not producing results. Thanks to all. Photos of part and car attached. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
