360/F430 F1 Actuator Centering methods | FerrariChat
Discussion in 'Technical Q&A' started by 24000rpm, Sep 18, 2017.
  1. 24000rpm
    24000rpm F1 Rookie
    I know there's a tool for physically centering the f1 actuator
    I also know in the SD2/3 there's a command that you can "center" the actuator
    Any difference between these 2 methods?
    Or maybe they are coarse adjustment vs fine tune?
  2. mb60
    mb60 Rookie
    Jan 23, 2013
    13
    Miami
    Matt
    To properly center the actuator, the 2 methods need to be done in conjunction with each other.
    The SD procedure is for putting the actuator in a hydraulically centered position.
    The tool is for mechanically centering the actuator finger.
  3. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,506
    Somewhere, anywhere
    Eddie B
    As above. You need the tool to put it into the correct position. It acts as a jig. The SD puts it into the position you need it in to use the jig. The control unit uses the two sensors on the end of the actuator to achieve that position..
  4. 24000rpm
    24000rpm F1 Rookie
    thank you guys
