348/355 - Master Sticky Thread Index | Page 2 | FerrariChat
Discussion in '348/355' started by rob lay, Jul 24, 2014.
  1. wildcat767676
    wildcat767676 Formula Junior
    May 20, 2011
    531
    Gilbert, Arizona
    Every sticky link pulls up the same thread that has nothing to do with any if the the stickies...
  2. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner
    Dec 1, 2000
    59,625
    Southlake, TX
    Rob Lay
    shoot, now the text descriptions are back for the links, I think maybe the SEO program was just down for a second.
  3. wildcat767676
    May 20, 2011
    531
    Gilbert, Arizona
    This is what comes up when I click on any of the sticky links:
  4. rob lay
    Dec 1, 2000
    59,625
    Southlake, TX
    Rob Lay
    no clue why it goes to a General Discussion thread. I don't use Tapatalk or like it.
    I can't get Tapatalk on my phone right now, but when I can will test it.
    Can someone else with Tapatalk please confirm?
  5. wildcat767676
    May 20, 2011
    531
    Gilbert, Arizona
    I love Tapatalk for iPhone but if there is another better app lemme know! The mobile browser sucks...lol 😁
  6. rob lay
    Dec 1, 2000
    59,625
    Southlake, TX
    Rob Lay
    I have iPhone 5S and just Safari is awesome for me.
  7. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,814
    Tinton Falls, NJ
    Bob Ferraris
    I got it all installed. I will edit the how to remove post above as a couple things I forgot came to mind on the install
    The pump comes on when the car is started. Not on ignition only. It makes a high pitched whine which is distinctive and not a normal sound from an engine. If you aren't hearing the whine reach down and wiggle the connector. In my case I didn't hear it and sure enough my suspect melted connector is still intermittent and on wiggling the pump came on
    I timed it for two minutes on cold start. The car was outside and it's hot here so not winter kind of cold start but hot summer cold start.
    I'm going to source the connector and pins and will add them to,this thread in case others have a similar issue as mine did. I definitely have never heard that whine before today.
  8. wildcat767676
    May 20, 2011
    531
    Gilbert, Arizona
    Any luck testing yet?
  9. rob lay
    Dec 1, 2000
    59,625
    Southlake, TX
    Rob Lay
    no I haven't, hasn't been a priority because are Tapatalk usage isn't very high and those users always have Safari etc. as alternative. It is most likely a tapatalk bug, not FerrariChat, one thing I don't like about tapatalk is how buggy and then people blame it on the forum. They have a big headache and challenge programming for multiple forums and mobile platforms.
  10. wildcat767676
    May 20, 2011
    531
    Gilbert, Arizona
    Ok thanks for the reply!
  11. zc911
    zc911 Formula Junior
    Mar 4, 2014
    707
    Brampton, Ontario
    Rob
    Question, how come I can only upload 1 pic per post from my iPhone?
  12. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Because apple is retarded and during uploads each photo has the same name "photo1"
  13. zc911
    Mar 4, 2014
    707
    Brampton, Ontario
    Rob
    Ahhhh boourns
  14. 355dreamer
    355dreamer F1 World Champ
    10,469
    DC Metro
    L.C.
  15. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
  16. FLORIDAsnakeEyes
    FLORIDAsnakeEyes Formula 3
    Jul 7, 2015
    1,146
    Sarasota, Florida
    OC
  17. Aventador1
    Aventador1 Rookie
    Apr 27, 2015
    16
    Australia/ LA
    Hey guys, how do you work out which number produced your F355 is? Thanks!! James
  18. 97 Spider
    97 Spider Formula 3
    2,241
    Texas
    Brian
    Maybe try starting your own thread asking this question? It's not exactly a topic for the Master sticky thread.
  19. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,814
    Tinton Falls, NJ
    Bob Ferraris
    #46 drbob101, Mar 19, 2016
    This is my experience with this issue and the resolution. There may be other problems with the system but Watson has found this etiology in multiple drives.
    Credit to Watson for the repair that I show here.
  20. vdettore
    vdettore Formula Junior
    Mar 3, 2017
    353
    Georgia Coast
    Vince
  21. cactussed
    cactussed Karting
    Mar 12, 2008
    232
    The o-rings on the fuel lines are standard BSO size 110. (width 2.62mm ID 9.19mm OD14.43mm).
    About GBP3.00 each from Ferrari, 10p from any bearing / seal shop...
    Qavion likes this.
  22. jeffdavison
    jeffdavison F1 Rookie
    2,544
    Suwanee Georgia
    Jeffrey Davison
    Ferrari part # 12354524 stud.... from vendors here in US 17.45 to 33.02 each
    Belmetric.com part# S8X24DSS.... price (as of 2-12-2020) .93 each, .72 each qty. 25 - 99. and .64 each qty. 100+
    This stud is used in the top shock mounts in all four corners. 16 total. 8mm thd 24mm long.
    It is also used in various other Ferraris in exhaust and other sub-systems
    05elise, Qavion and Wade like this.
