308/328 GTB/GTS / DINO GT4 PARTS CROSS REF. THREAD | Page 17 | FerrariChat
Discussion in '308/328' started by thecarreaper, Jun 25, 2005.
  1. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,319
    maurice T
    The brake/stop light switch from a Fiat 124,126,127,128,141,132,850,Argenta,Regata,Ritmò,Uno X19 is the same as the one used on the 328,,
    This is correct for my 1987 at least,88.5-89 may be different..
  2. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,086
    SanFrancisco BayArea
    1983 US 308 GTS QV
    #402 Brian A, Apr 24, 2017
    Replacement zipper sliders for the rear storage trunk cover can be purchased from Rocky Woods Fabrics (Rockywoods.com) as item "PU-C5 Black" which are described as "Metal slider with single pull for #5 Coil YKK Zipper". They cost $0.50 each (current price).
  3. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
  4. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,086
    1983 US 308 GTS QV
    The 308 mirror adjustment switch is readily available from BMW parts vendors, both as new and used.
    The BMW part number is 61-31-1-363-459.
    It was used in the 1981 - 1988 BMW 5 Series. In BMW parlance, that vintage 5 Series model is referred to as the E28.
    As a baseline, Pelican Parts currently sells the new switch for $56 and I bought a used one yesterday from Double 02 Salvage for $20.
  5. vp277
    vp277 Karting
    Mar 1, 2010
    101
    LI, NY
    Sanden AC compressor for euro cars: Sanden 6332 (SD5H11). Exactly the same as the original, available from tractor supply stores.
  6. theunissenguido
    theunissenguido Formula 3
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
    Can you give us an exact website reference....to many tractor supply stores on the net that haven't Sanden in their collection.
    Thanks, Guido
  7. knocker
    knocker F1 World Champ
    11,854
    Sydney Aus
    Adrian
    Hi 308 section folk Can any one tell me if the V 6 3.2 fiat 130 engine would fit in a Ferrari Dino gt4 just curious (track car)big question I know has anyone done it
  8. knocker
    11,854
    Sydney Aus
    Adrian
    Strike that question blame it on the pavlova
  9. BigTex
    79,218
    Houston, Texas
    Bubba
    Gates poly accessory belts:
    Always hard to find these, as Auto stores "don't show our numbers"
    Radwell International Inc.
    800 332- 4336
    Michael Edoff Ext. 1174
    [email protected]
    Now the 308s have two different 'early' and' late' pully sets.
    But my alternator belt is a Gates #7M975
    So, get your other belt sizes and give these guys a call!!
    It worked in 2014, any way.........
  10. Kidasters
    Kidasters Formula Junior
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    Just an update, since I couldn't find the info I needed searching this thread.
    My air pump went out, and I wanted to replace it.
    Searching All of F-Chat - I thought the A-1 Cardone 32207 was the correct air pump. It arrived Friday. While the body is similar, it would not work. The boss where the pump attaches to the arm coming off the head is large and unthreaded. The boss where the pump attaches to the bracket on the head of a 308 with the long bolt was threaded. I might have been able to rig something that would work if I felt like it. I don't.
    The next part I will try is the AC Delco 215-143. The pictures I've seen of this pump show it with at least threads in the correct areas. It will be here Thursday, and I'm hoping it will work.
  11. absostone
    absostone F1 Veteran
    9,281
    isn't there a GM part that fits ? I thought I recalled that
  12. Kidasters
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    The AC Delco part 215-143 is also not a bolt in replacement. Again - the bodies were cast from the same mold, but there are threads where there should be a smooth bore, and a smooth bore where there should be threads. You can attempt to mount it upside down, but the heat shield won't fit, and the air nozzle is in the wrong spot.
    I have found the OE pump on e-bay for a decent price. I'm using that.
    NoGoSlow likes this.
  13. thecarreaper
    thecarreaper F1 World Champ
    17,585
    Savannah
    Glad to this thread is still alive and evolving. :)
  14. Baltz1969
    Baltz1969 Karting
    Apr 24, 2017
    69
    Chula Vista, CA
    Jose Baltz
    Using the casting number I got a remanufactured pump from Autozone. The mounting bolts are reversed. I placed the long bolt on top which made it easier to instal and remove for future service. I used two bolts for the lower mount. Works like charm. The pump was about $100.00 no core.
  15. absostone
    9,281
    part number from Autozone?
  16. Baltz1969
    Baltz1969 Karting
    Apr 24, 2017
    69
    Chula Vista, CA
    Jose Baltz
    32-207 cardone. I also got the check valves for about $15.00 part # 355050 Dorman
  17. absostone
    9,281
  18. Baltz1969
    Baltz1969 Karting
    Apr 24, 2017
    69
    Chula Vista, CA
    Jose Baltz
    On an earlier post someone combined two air filters to fit it on an injected 308. I found that STP filter part # SA101118 fits like a glove with minor shaving on the both ends (about 1/8) Autozone $13.00. Box indicated cross reference to Fram #CA10118 AC Delco #A3115C Microgard #MGA49192 & Driveworks #DW25635
  19. Tvjake2
    Tvjake2 Karting
    Jun 28, 2017
    129
    Glendale, CA
    Tom J.
    Carb 308 Air Cleaner Knurled nuts - cheap
    My mechanic misplaced several of my little "bolts" or knurled head nuts (which is what I also call my youngest brother) so I went online and searched and found them at several sources...all at about $10 - $24 each depending on the source with shipping adding some interesting cost to the transaction. I also own a 1989 BMW 635CSi. I was looking at the knurled nut on the power steering reservoir and noticed that it had a similar nut. I pulled one of the stock nuts off the Ferrari and tested it on the BMW and it fit! (See attached pics, the nut on the BMW is upside down from the Ferrari application) The nut for the BMW is just slightly larger but much cheaper at $4-$5. Just paint them satin black and no one will know the difference unless they get out the micrometer. If you want them without shipping just go to a BMW dealer and order them.
    Knurled Head Nut - BMW 32411128170
  20. waymar
    waymar Formula 3
    Sep 2, 2008
    1,324
    Northeast, PA - USA
    Wayne Martin
    BAE209B1F (1982 308GTSI Coil) OEM
    Lenmark CP195
    The OEM coil has the secondary output on top. The replacements I have seen only have secondary output on the side which are to wide for the OEM bracket on my year/model. The Lenmark CP195 is for a Fiat of the same year has the output on the top and looks like OEM.
    My OEM coil measures: Pri 0.7 ohms and Sec 3,940 ohms. The replacements have Pri 0.35 and Sec 6,900
  21. waymar
    waymar Formula 3
    Sep 2, 2008
    1,324
    Northeast, PA - USA
    Wayne Martin
    Lenmark should read Lemark in the above post. Couldn’t edit it.
  22. absostone
    9,281
    Exhaust spring #111743
    26mm length
    O.D 18.75
    I.D 10.6
    WIRE 4mm
    Thank you Wildcat 326
  23. AdamBoca
    AdamBoca Karting
    Mar 14, 2018
    55
    Bowling Green, KY
    Adam Boca
    Any cross shared front bumper shocks?
  24. Cirorsi
    Cirorsi Formula Junior
    Nov 10, 2016
    790
    Louisiana / Lac du Saint Sacrement, NY
    Steven
    Anyone know of a good brake booster replacement on an 85' 308?
  25. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,086
    1983 US 308 GTS QV
    L'Oréal #236 "Valentine" nail polish is a close match to Rosso Corsa.
    Nail polish is lacquer, so is good for temporary touch-ups since it is easily removed again without damaging the surrounding paint.
    ... please stop laughing.
    Tvjake2, WaltP, thorn and 2 others like this.
