250 HP Mondial, Cheap Ferrari,, etc. | Page 6 | FerrariChat
Discussion in 'Mondial' started by 350HPMondial, May 30, 2014.
  1. 350HPMondial
    350HPMondial F1 Veteran
    5,195
    Edwardo
    #126 350HPMondial, Sep 5, 2015
    Put in all 8, NGK BP 7ES spark plugs.
    All wires.
    Check.
    Got Good fuel pressure, with no leaks.
    check.
    No water yet, so I'm going to run her for 30sec.
    Check,
    hit the Start button, sending 12V to the Ferrari factory FIAT freakin starter motor ,
    and......??
    Erk....!!! She said.
    Ha ha, weak,
    Lame, factory starter,, just can't spin her.
    Not with my new 9.9 to one JE pistons.
    Hoo Raa.
    Called Mr. McGehee and Mr. Gustafson. A Gustafson Starter to be sent ASAP.
    ( smile )
    Go get a beer.
    To be continued.
    Edwardo
  2. 350HPMondial
    5,195
    Edwardo
    #127 350HPMondial, Sep 5, 2015
  3. 350HPMondial
    5,195
    Edwardo
    #128 350HPMondial, Sep 10, 2015
    Help.
    Does this Gustafson 308GTSi starter use the factory bolts...?
    Or, are the tapped holes English..?
    Starter is up in the car.
    And,
    No, I don't want to take it out.
    Edwardo
  4. 350HPMondial
    5,195
    Edwardo
    #129 350HPMondial, Sep 10, 2015
    Ok, ok I took it out,,, again.
    Chased the M8 threads with a Tap.
    The were a little tight.
    Hey Kieth,
    Slow down the feed rate on your CNC tapping process
    Ok,
    Ok,
    And,
  5. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    Hey Edwardo, why that kind of starter?
  6. 350HPMondial
    5,195
    Edwardo
    Bell,
    Needed a starter with Cahones'
    Hoo Raa
    Edwardo
  7. Bell Bloke
    Dec 6, 2012
    1,839
    Oh, have you changed the compression ratio on this car?
  8. 350HPMondial
    5,195
    Edwardo
    Bell,
    Yes,, my compression,
    To be yet measured , but as Calculated.
    Now maybe 9.9 to One.
    But, hey this new Starter is the Whizzard of All,, Starters.
    FerrariStarters.com can get you a Gustafson starter also.
  9. 350HPMondial
    5,195
    Edwardo
    Update,
    Got great oil pressure.
    If I jump fuel pump, it works, with good pressure. ( cold and warm pressures to be checked.)
    Got 12v to coils, yellow wire.
    But, no volts to the Tan Fuel pump wires on Conn. "W"
    Replacing the Relays in the WUR, FP and AAV circuits,, they might be old and weak.
    And,
    Going to bypass the Fuse Box, Burned Tan wire Conn. ( connector 7) on "W,"
    with an external Relay. But, relay power needs to come from the Ignition key, yellow wire 12v out.
    And, fuel pump power from the battery with an inline fuse holder.
    See Mondial Electrical Fixes.
    http://www.ferrarichat.com/forum/mondial/87920-mondial-electrical-system-thread.html
  10. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    I bow to your continued greatness and devotion...keep it up!
  11. 350HPMondial
    5,195
    Edwardo
    A Ha,, my sensor wires are Wrong.
    Color coded Connectors don't match.!????
    But, the color of the wires in the harness shows a different story.
    Easy fix, got 73 kOhms on the sensors now, measured at the Digiplex Connectors.
    Whew.
  12. 350HPMondial
    5,195
    Edwardo
    Got fire.
    Got spark in 8 cylinders.
    Great oil pressure.
    To be continued...
    Edwardo..
    Ok, ok,, why no injection..????
  13. 350HPMondial
    5,195
    Edwardo
    #138 350HPMondial, Sep 19, 2015
  14. 350HPMondial
    5,195
    Edwardo
    #139 350HPMondial, Sep 19, 2015
    Rear window installed with new seal,, and, the vertical crack was repaired,, $200.00 tip.
    And,
    WUR,, warm up regulator, Out.
    They go BAD over time.
    (Mine is 34 years old.)
    Ordered new WUR from the Deloran guy.
    And, My fuel pressure was out of control.
    But, started the car.
    Hoo Raa.!!!!
    Just manually controlled the fuel pump power.
    Then rerouted the fuel pump power, and back fed the AAV and the WUR.
    Edwardo
  15. 350HPMondial
    5,195
    Edwardo
    #140 350HPMondial, Sep 23, 2015
    Wheels on, and sitting.
    My Stance..?? Well, I seem to have a lot of , aaaaa, wheel travel.
    Ha
    My tires look like ball bearings,, I need some 60 series tires,, these are all Mechlin 205 55ZR 16, or some 348 17" wheels??
    Later,, l
    Now, I'm looking for a Bosch WUR. An 083 or a 132.
    The 083 are All gone or lost.
    I have the only 083 left.!! and I'm sending it in for repair
  16. 350HPMondial
    5,195
    Edwardo
    #141 350HPMondial, Sep 23, 2015
    She's
    ,she's
    ALIVE......!!!!!
    Aaaaaaaaaaaaaa,, Insert ( evil laugh .) here.
    Got 8 cylinders of Fire and OK fuel pressure. Need new WUR.
    And,
    Got the fan to turn on.
  17. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    11,990
    FRANCE
    That's wonderful, Edwardo...
    Rgds
  18. MvT
    MvT F1 Rookie
    May 25, 2013
    4,248
    The Netherlands - NH
    Tijn
  19. 350HPMondial
    5,195
    Edwardo
    #144 350HPMondial, Oct 31, 2015
    Yes, I contacted them.
    They were Very helpful,, thank you.
    WUR to be sent in soon,, right now it works OK, for smog check.
    AAV seems weak too.
    I'll check this soon.
    See New GTV6 Alfa Clutch cylinder.
    The Resavour Unit is a drop in replacement.
    ( No, my factory Clutch Slave Cylinder is not for Sale.)
    Edwardo
  20. 350HPMondial
    5,195
    Edwardo
    #145 350HPMondial, Nov 3, 2015
  21. mwr4440
    55,945
    Bavaria, The 'Other' Germany
    Mark W.R.
    Ed,
    Get hold of Ferrari400. He sells repair kits for the WURs.
    You can DIY.
    Not much to them really.
  22. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Ponte Vedra Beach , FL
    Don Franzen
    Congrats on the Fire Up!
  23. 350HPMondial
    5,195
    Edwardo
    #148 350HPMondial, Dec 10, 2015
    Thanks,, took Eight years.
    Hoo Raa.
    New Rebuilt WUR from Deloran Guy.
    Check.
    Clean Plunger in Fuel Distribution Unit.
    Check.
    Proper operation of Aux Air Valve,,
    Check.
    Thermo time Switch.
    Check.
    New Broad Range Oxygen sensor in Foreward Bank.
    ( This bank misses Horribly during motor warm up phase, with high Fuel Press.)
    Ok,, but, check. For I have Stoichiometric read out of 14.7 during car operation at Normal Temperature.)
    Big Check.
    Next, Smog Check at a Mercedies Benz specialist.
    Smile.
    Edwardo.
  24. jgoodman
    jgoodman F1 Rookie
    3,203
    Central PA
    Jay Goodman
    Congrats Ed! Been a very long journey. Glad you can finally start to enjoy her again.
  25. FCnew
    FCnew Formula Junior
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    Wow... EIGHT years ?!?!?!
    This car must have cost $100k+++
    I am glad it is near the end.
    Looking great +1
