348 - 348 Parts Thread | FerrariChat
348 348 Parts Thread
Discussion in '348/355' started by plugzit, Mar 1, 2005.
  1. plugzit
    plugzit F1 Veteran
    7,781
    Redondo Beach, CA
    Bruce Bogart
    Who has sourced parts from outside Ferrari or discovered parts that interchange from other (less expensive) brands of cars? Could we compile a list of parts and numbers?
    Example-Glove box strut-$65+ from Ferrari: ?(worth $10) from somebody else listed as a part for a VW
  2. jcollingridge
    jcollingridge Karting
    Sep 8, 2006
    70
    Kamloops,B.C.,Canada
    Jim Collingridge
    Excellent idea for not only 348 but for Ferrari 308,328 models. An alphabetical list of common parts with could get you home in the event of a road trip emergency repair. Such as cross reference numbers for A/C, water pump, air pump belts, oil, air and fuel filters, wheel bearings National Bearing numbers, rad hoses and thermostat numbers, etc. Jim
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Fuel pressure regulators are Ferrari part number 147281 (Bosch #0 280 160 731 available for $138 at thepartsbin.com), about $440 each at Ricambi or an outrageous $500+ at Ferrari dealerships. But...I'm reasonably sure that they are just AC Delco FP regulators. The AC Delco part number is 217-2119 and the GM part number is 35476530. You can get them for $81 each here if you don't mind forgoing the pretty yellow Ferrari shipping box: http://www.autopartsgiant.com/CAT_FRAMEX.cfm . The STANDARD MOTOR PRODUCTS FP Regulator # PR171 (~~$75 at RockAuto.com) should work on our 348's, as well. The AirTex Fuel Pressure Regulator (Part # 5G1020) for our 348's is only $59 at RockAuto.com, too. These fuel pressure regulators should all be exactly the same, and interchangeable at will.
    eees likes this.
  4. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    348SPIDERMAN likes this.
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    $80 348 water pump rebuilds: Mr Dick Jordan, 7105 Fountainbleau Road, Ocean Springs, MS. 39564 (228)872-0855 European Waterpump Specialists - thanks, sulzeruk
    eees, 348SPIDERMAN and F1Flaherty like this.
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Pre-1993 348 Outer Rear Wheel Bearings (SKF): new from Applied = $105 each http://www.applied.com (877-279-2799), or $113 from Ferrari of Dallas for bearing part #144807 (SKF # 62209-2RS1 or SKF 62209-2RS2), or $40 each from Gerardi Bearing Co.(Salinas, CA).
    Outer rear wheel bearing hub assembly for 1993-1995 348's was Ferrari part #143172 and is now #157900 (new $677 at Ferrari of Atlanta, $594 at Ferrari of Dallas, $456 at ferraripartsexchange.com, or $368 from EuroSpares).
    Pre-1994 outer Front Wheel Bearings for 348's (and for most Ferrari's made from the 1970's up through to the 348) can be purchased for less than $15 here: http://www.autopartsgiant.com/CAT_FRAMEX.cfm (post 1993 cars can retrofit to these bearing by purchasing some additional older axle components).
    The 348 uses a Porsche 911 turbo (930) CV boot. The 348's CV joint is 108 mm diameter x 40mm wide and the Porsche part # 90133229312 boot should fit it and cost about $6 per boot (no grease or clamps). Ferrari uses industry standard, third party LOBRO CV joints, supplier to VW, Audi, and Porsche among others ( http://www.drivewire.com/index.html ).
    eees likes this.
  7. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    NAPA carries the superior Borg Warner 4-wire "generic" O2 sensor for the 348 ($25 each on eBay). These are 4 wire O2 Sensors that need to be spliced to your original O2 black plastic electrical connectors. This BWD/BG part number is OS582, though NAPA may list it under various NAPA part numbers differently.
    Bosch makes a universal sensor, Part # 15727, that works perfectly on the 348. http://www.oxygensensorwholesale.com/ferrari_1994_348-spider.html .
    Also the plug-and-play BOSCH OEM O2 sensor itself (Bosch part # 13120 or 13240) can be had at Auto Zone for a mere $160 (and the aftermarket 348 Walker plug and play O2 sensor that requires no wire splicing is only $110: http://www.automedicsupply.com/index.php?&engine=V8-3.4L&stopredirect=yes&width=800&height=600 )
  8. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    One potential Mondial T/348/355 replacement alternator, new from NAPA, part number is 13-4553. The Delco part number is 10479969. GM part number: 1101267 Cost: $144. The regulator is "made in Costa Rica" and has 35-127-7 0107-7 on it, the rectifier says CARGO 131880 M090 RD-02T A14938.
    This regulator is superior to OEM: INR734P REC ND.
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  10. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    The Sachs part number for the 355/348 engine lid and front hood struts is SG437007. rockauto.com has them at $26.79 each...plus $4.01 each for shipping. - thanks, DaveHanda
    I still have the old Stabillis 348 hood strut, so I took it to the Audi spare shop again and bought another one. Both ball joint ends including the shaft are chrome while the original are black. The body Cylinder is black. The make is "TRIDON" and the part number is 4B5 827 552D for the rear bonnet of the Audi A6 (C5) . It cost me another $33. Be warned that it is slightly fatter than OEM 348 and extra strong even with just one. If you change both, you might bend the bonnet trying to close it! Even with just one on the rear, I have to put a hand on the cover before I pull the level as it will spring up. - thanks, William Heung
    Dino Militello likes this.
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Black horizontal body stripe, it is 3m body seam sealer . 3m numbers are 08364 or 08500. Thanks, MDShore348
  12. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #12 No Doubt, Sep 22, 2006
  13. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #13 No Doubt, Sep 22, 2006
    Part #53 below (white plastic) often breaks. It's a common plastic automotive cable retaining clip (same as for all Chrysler cable latches as well as Ferrari 348, F355, and 360). It's Ferrari part #63291200. You can get it here (http://ricambiamerica.com/product_info.php?products_id=253848) for $0.45. Pep Boys calls it a "door lock rod clip." *thanks, Miltonian and Oper8
    ernie reports that an improved version is the same clip in nylon from Audi.
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    348 Windshield Wipers: Bosch part number for a complete set of the 500mm blades (20 inches) including the aero wing is: 3 397 118 561
    Refills only part number: 3 391 014 603 (thanks, fnu_lnu)
  15. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  16. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Replacing Cam O-rings (and fixing oil leaks) Without Removing Engine!
    ...it can be done in situ, i had it done 2 months ago. You remove the camcovers, cut the o rings out,then spend a lot of time cleaning around the opening getting all the sealant out and flush it with power clean.
    To put the new ones in you cut them with a very sharp knife and feed it round till you have both ends at the top and stick it back together with super glue,put the gasket seal over the rubber and bolt everything back together.
    It takes time getting it cleaned out, it's done quite a lot over here and works fine. Mine were pissing oil, now they're as clean as anything. - Thanks, Andy Hls
  17. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    The Ferrari 348 MAF part # from Bosch is: 0 280 212 018. This part is also used on some early 1990's series Saab 900 and 9000 non-turbo vehicles. The Saab MAF's (0 280 212 017 and 0 280 212 018) are set to a widely different resistance value, so you will have to reset this value to 383 ohms for your 348.
    The Saab MAFs typically sell for less than $10 used on eBay.
  18. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Red Line's "75W90NS" replaces and obsoletes the 348's OEM tranny fluid.
  19. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  20. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    OEM #155226 CLUTCH RELEASE (throw out) BEARING for 1993 THRU 95 348TB/S (SKF # BB1B631107) - also #177784 (shared with 355), #168594 (for twin discs), and # 176560 (for twin discs). 176560 was updated/replaced with bearing #168594.
  21. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  22. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    The 348's $155 Ferrari speedometer pulse generator # 116987 (mounted on transmission) may be superceded by the newer Maserati # 393650106, which retails for less than $50 at www.EuroSpares.co.uk.
    You must also buy and install a new gasket with either new speedo pulse generator/sensor. The gasket for it is Ferrari # 10263460.
  23. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    The electronic parts that comprise 348 gauges are generally inexpensive.
    Parts R Us carries the speedometer gauge IC (HCF4024BE) for sixty cents, for instance: http://www.partsrruss.com/digital.htm
  24. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  25. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
