Road Angel2----------------------------------- | FerrariChat
Discussion in 'United Kingdom' started by tonyh, Aug 20, 2004.
  1. tonyh
    tonyh F1 World Champ
    Dec 23, 2002
    14,372
    S W London
    Tony H
    How long should it take for the unit to aquire sat. lock? I'm finding mine takes at least 15 mins and sometimes it won't find a lock at all.Am i doing something wrong? What shd settings be ? Help pls! :confused:
  2. 208 GT4
    208 GT4 Formula 3
    Dec 27, 2003
    1,764
    Brighton (UK)
    Dan
    If you're too close for missiles, you could try switching to guns?
  3. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    Funny .... ;)
  4. ric355
    ric355 Guest
    Dec 21, 2003
    1,375
    I don't have a road angel but I do have an in-car GPS receiver. It takes from 30 seconds to 2 minutes typically to acquire a satellite lock. On very rare occasions I have found that it has trouble acquiring a lock at all. However in those circumstances I've always found a reason for it - eg on one occasion the receiver had moved along the dash and was getting obscured by the windscreen wiper, thus blocking the signal. As soon as I moved it, it was ok.
    Where is it positioned in the car?
  5. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    To the left of centre of dash. Wiper shouldn't be a prob but i'll double check.cheers for tip, m8.
  6. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    #6 tonyh, Aug 20, 2004
  7. noony
    noony F1 Veteran
    Nov 25, 2003
    5,903
    Seoul
    Johnathan
    Do the wipers go from the centre? If so then they are right in front of it. From which direction does it receive signal?
    I remember sitting there :)
  8. RAY430RED
    RAY430RED Formula 3
    Nov 1, 2003
    1,112
    Marlborough Wilts
    Ray F
    Have you got one on you push bike Noony if so keep it clear of the BELL LOL HAAHAHAHAHAHAHA
    RAY360M (with mountain bike )
  9. noony
    noony F1 Veteran
    Nov 25, 2003
    5,903
    Seoul
    Johnathan
    Ray you're a nice guy so I won't make a stunningly witty comeback.
    (I could've said ''the only bell round here is on your head'' :p:d)
    all in good humour
  10. RAY430RED
    RAY430RED Formula 3
    Nov 1, 2003
    1,112
    Marlborough Wilts
    Ray F
    Noony i got another one somewhere else When your older you will learn to use it (ask your dad if you dont understand ) LOL hahahahahaaaaaaaaaaaaaaaa
    Ray 360M (bell end average )
  11. ric355
    ric355 Guest
    Dec 21, 2003
    1,375
    Doesn't look like it would be obstructed. I can only suggest you sit in the car with the top down and hold it up so it has a clear view of the sky, and see if it manages to get a lock quicker like that - not a solution but might help with diagnosis.
    Richard.
  12. Uonlyhave2seats
    Uonlyhave2seats Karting
    Feb 25, 2004
    52
    South East, UK
    Tone
    Tony, I have a road angel 2 and it locks on very quickly.
  13. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    Are your settings factory default ? Would you mind running through what you have on here, pls?
  14. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    I have a Snooper which uses the same technology, shouldn't take that long to aquire but I agree that obstructions like wipers or certain built in sunstrips can affect. On leafy lanes for example the unit sometomes loses the plot for a while due to tree cover. I did have a software problem and found the help desk really helpful and problem solved quickly. Good luck!
  15. Garyh
    Garyh Karting
    Jan 10, 2004
    140
    Tony,
    I have a Road angel 1 which occasionally takes a good 5 minutes to lock on. As i have had the same on the sat nav on my Audi (but not the F car?) i always put it down to atmospherics ! Usuallu unplug it and it locks on as soon as i reconnect but maybe the Road Angel is weak in ths area. Good luck!
    Gary
  16. stevep
    stevep F1 Veteran
    Jan 19, 2004
    8,345
    Geordie Land
    steve
    tony ring tech support number on road angel box, mine doesnt take that long 30sec-1min
  17. Uonlyhave2seats
    Feb 25, 2004
    52
    South East, UK
    Tone
    Tony, not sure what the settings are, we bought several, someone set them all up before handing them out.
  18. matkat
    matkat Formula 3
    Mar 18, 2003
    1,840
    Scotland
    Dave McGuire
    Something wrong there Tone,my RA 1 takes a couple of mins even from a "cold start"and it is also factory default setup,the only way it should take a while would be if you are around high buildings.
  19. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    Thanks for all the replies. I've switched unit over from left of air con vents to far right corner of windscreen and it's working fine. DOH :p
  20. ferrari355gtb
    ferrari355gtb Formula 3
    Nov 3, 2003
    1,600
    R
    Tony - what are your impressions of the Road Angel ? Worth its money ?
    Thinking of getting one too but also looking at Origin B2.
    Rick
  21. Robertb
    Robertb Formula 3
    Nov 19, 2003
    1,331
    South Oxfordshire, U
    Robert
    I had a Road Angel version 1 and it took ages (45 mins one day) to get a signal. The car was garaged overnight which seemed to confuse it; when starting from the office (car parked outside) it was fine.
    I took it back for a refund in the end; my car has GPS and it has no probs with signal location in the garage...
    Robert.
  22. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    Rick,
    i don't have anything to compare it with as i haven't had a detector before . It picks up ALL Gatso sites, ALL traffic blackspots, is VERY sensitive when set to pick up traps from over 250M....It seems to be like that Ronseal stuff.....
    It does exactly what it says on the box.......
  23. 360CS
    360CS F1 Rookie
    Nov 1, 2003
    2,641
    Kent
    Joe J
    iM LOOKING AT PURCHASING THE SAID DETECTOR??
    Tony any recommenations m8 ?
  24. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    Joe,
    as i said below, i haven't got anything to compare it with.I had trouble early doors because it wouldn't lock onto GPS satelites, but that's prob cos i had it in wrong place in car ! That said , since i repositioned it to right side of me , it's been spot on.
  25. 400SPYDER
    400SPYDER F1 Rookie
    Jul 7, 2004
    3,473
    Kent, England
    kevan
    Lifted this straight from a pistonheads review:-
    jon astley "Insurance companies hate them so beware"
    Fantastic piece of kit but my experience in informing my insurance company was astonishing.
    Basically esure have informed me that it is a modification to the vehicle and as such invalidates my cover.
    Whats more if I didn't confirm that I had removed it they would cancel my cover in 7 days!
    In addition, having confirmed that I would remove it, they informed me that it would be registered on my file and if I have an accident and one is found in the car or mentioned in the police report they would refuse to pay out. No idea if this is common.
