What if I 'just' have the red key fob???? | FerrariChat
Discussion in '360/430' started by CyclingPeaks, Jul 16, 2008.
  1. CyclingPeaks
    CyclingPeaks Formula Junior
    Jun 11, 2006
    361
    Big Island, Virginia
    Hunter Allen
    Ok, I am looking at a 360(my previous one went to Ferrari heaven) and it only has the red key fob.
    So, does that mean, I can buy a black one for $700 and then program it?
    Or not.....
    thanks.
    Hunter
  2. duskybird
    duskybird F1 World Champ
    12,571
    29 Electoral Votes
    Bill B.
    IIRC the black fobs are about $100 each. Get at least 1 program it and put the red one away
  3. toshiba
    toshiba Formula Junior
    Jan 14, 2008
    725
    Santa
    what this guy said
  4. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,956
    MD and NE
    Robbie
    Find a couple black fobs on Ebay and have them cloned from the red one...There is an Fchatter from France that can do this..He did a couple for me and they work fine..... Just remember the Euro fobs and US fobs use a different frequency--So make sure they match before buying them...
  5. duskybird
    12,571
    29 Electoral Votes
    Bill B.
    You can "clone" them yourself that's what the red one is for.
  6. Skidkid
    Skidkid F1 Veteran
    9,502
    Campbell, CA
    John Zornes
    I have resisted so far but this is one of the urban legends. The red fob doesn't change the black fobs in any way. The red fob can be used to put the system into learn mode so it can learn to recognize black fobs.
  7. zippyslug31
    zippyslug31 Formula 3
    Sep 28, 2007
    2,075
    PDX
    Kevin M.
    Hunter, that sucks, what happened????
  8. CyclingPeaks
    Jun 11, 2006
    361
    Hunter Allen
    wet road, kinda worn rear tires, curve, 65mph= instant swappage of ends and guardrail city. There was no saving her.
    It was a very, very, very sad day. ;-(
    Insurance did right though, so I'll be able to get another. If I can just find what I want!
    Hunter
  9. OKA
    OKA Karting
    May 7, 2008
    217
    Houston, TX
    Sam
    So with the red FOB you don't need the Alarm code to program the black FOBs?
  10. Skidkid
    Skidkid F1 Veteran
    9,502
    Campbell, CA
    John Zornes
    That is my understanding. Remember that the process is a little tricky and, from what other say, not too reliable so you can do it a bunch of times before you get it right. There is one great thread on here with the specifics. I will try to find it and post a link.
  11. NPWMD
    NPWMD Karting
    Apr 16, 2006
    80
    NY,FLA
    Neal P Wittels, MD
    The red fob allows one to program a new set of fobs without the alarm code. If one presses the red fob it puts the ECU into programing mode then one presses the new red fob and then the two black ones one by one. It is used instead of the alarm code.
  12. mjw599
    mjw599 Formula Junior
    510
    A Chinese Democracy
    John, you mean this thread?
    http://www.ferrarichat.com/forum/showthread.php?t=132424
  13. zalbahadurji
    zalbahadurji Karting
    Dec 6, 2006
    64
    Boston/Dubai/Mumbai
    is this a joke??!! i've been using a red key fob for a year and a half now!! am i doing something wrong? it's a 430 though, not a 360.. am i supposed to have a black key?!
  14. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    totally different systems
    if you have a 430 you need not concern yourself with this thread (unless you want to learn about the 360 key system)
    on the 360 you're supposed to get two black and one red key. the black ones are for daily use. often, through the years, some of the keys go missing leaving the new owner with some variation on the 2 black/1 red design.
    on the 430 we don't have the black/red difference... only red keys. but know that our red keys do not equal the red key on the 360... again totally different system.
    frank
  15. FAST348
    FAST348 Karting
    Dec 31, 2006
    100
    West Central Ohio
    Aric
    I have a 2000 360, delivered about 2 wks. ago w/2 black fobs. All is well and all works fine but I am wondering - the red fob I am missing - what does it do and do I really need one? Thanks in advance.
  16. duskybird
    12,571
    29 Electoral Votes
    Bill B.
    The red fob is the master. Should you loose/break your black remotes you can use it to program new black remotes. Did you get the alarm pin?
  17. FAST348
    FAST348 Karting
    Dec 31, 2006
    100
    West Central Ohio
    Aric
    I think I got the alarm pin, I'll check tonite and post tomorrow, Thanks
  18. NPWMD
    NPWMD Karting
    Apr 16, 2006
    80
    NY,FLA
    Neal P Wittels, MD
    The red fob can be used to program a new set of fobs purchased from Ferrari. The set includes one red and two black fobs as well as a new code. The old code is not needed. In your case if you do not have the current code or the red fob then you need to call Ferrari for the old code and reprogram from that. If the old code from Ferrari does not work then you need a new ESU. Good luck.
  19. Rifledriver
    36,941
    Not what the red fob is for.
  20. Rifledriver
    36,941
    Red fob doesn't do that either.
  21. NPWMD
    NPWMD Karting
    Apr 16, 2006
    80
    NY,FLA
    Neal P Wittels, MD
    So, what does the red fobs do?
  22. Rifledriver
    36,941
    There are a ton of threads on the subject and has been gone over as many time as when the belts should be changed but...
    It is the only one that can program the frequency of the ecu when that set of fobs is assigned to that car..
    The fobs frequency is set and is not designed to be changed
  23. NPWMD
    NPWMD Karting
    Apr 16, 2006
    80
    NY,FLA
    Neal P Wittels, MD
    I have checked the threads there is no where any explaination of how the red fob works.
    More importantly, There will be now if you know.
    I am confused by your reply. Are you saying that, if you have a red fob you can reprogram other black fobs to that frequency? I understand that the red fob puts the ECU in a programing mode to accept another set of fobs. Please clarify.
  24. Rifledriver
    36,941
  25. NPWMD
    NPWMD Karting
    Apr 16, 2006
    80
    NY,FLA
    Neal P Wittels, MD
    Neither of those threads says exactly what the red fob does. I would like to know exactly what the use is, if you know. Does it only reprogram the same black fob that looses it's programing or new fobs, what?
