Cam drive-gear bearings..engine remove? | FerrariChat
Discussion in 'Technical Q&A' started by marks308GTB, Jan 11, 2005.
  1. marks308GTB
    marks308GTB Karting
    Jun 6, 2004
    114
    Los Altos Hills, Ca.
    Mark S.
    I have a 1976 308gtb. It may need a new set of inner cam drive- gear bearings. Does anyone know if it is possible to replace these without removing the engine??
    I already have replaced the outer bearings. Have new tensioner pulleys/bearings already, too. Installed new water pump. Still have some light growling noise. Not sure exactly what it is, but could it be the inner bearings?
    Any help would be appreciated.
    Thanks,
    Mark
  2. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    It's definitely doable. I've done it a couple of times. Unfortunately the posts with most of the pix are currently off-line in the old fchat archives. Also did it to JWise's car more recently (both w w/o pulling the engine, guess we needed the practice.) There's a long writeup on it, but the pix are also off-line.
    Short version:
    Remove the sump cover, then remove the oil pickup tube & double-nut the pickup tube studs off. Will need a good basic set of auto tools, plus: Snap-On 'short' 12-point 1/4" drive flex socket w/ 14" & 12" 1/4" drive extensions, a 10mm wrench with about 3/4 of the box end ground down very thin.
    Then remove the studs going up thru the sump's front lip into the timing cover's base, again double-nutting them.
    CAVEAT: If you can't get just one of the oil pickup, or the timing cover base, studs out, then you have no choice to pull lthe engine(been there too). Luckily most of the time this doesn't happen, so the odds are in your favor.
    If all goes well, it's a 3 to 4-day job, but for a 1st timer, it'll probably take 6 days.
    If the timing cover stud boss hangs up on the WP, you'll have to either pull the WP, or else trim the intersection with a hacksaw blade.
    Most of the rest is pretty straightforward. Feel free to post more questions to this thread as you go along. Also send me eMAIL & I'll give you my phone # & talk you thru if necessary.
  3. marks308GTB
    marks308GTB Karting
    Jun 6, 2004
    114
    Mark S.
    Thanks for the help on this. Yes, I watched you go through the work on yours and then was dissapointed to see the photos go offline.
    Anyway, I am not sure that I am up to this myself. Plan to check with a good mechanic and see if we can follow your lead on this.
    Will let you know on our progress.
    Mark
  4. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Are you sure it isn't your girlfriend in the next seat??? ::)
    hth,
    chris
  5. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    Are there any upgraded bearings for the cam drive & tensioner bearings??
    It lseems fairly clear from the 4.1 engine post that the bearings are a "bit" under-engineered, or at least, under-speced.
    Can anyone out there list better quality bearings #s for the early carbed 308's???
    Just looking down the road, so when i do the belts, i will have all of the necessary parts.
    thanks,
    chris
  6. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    I'm not convinced that the OEM bearings are badly under-spec'd. The early carb'd 308s had the bearings in-board of the seal. Big advantage: Both bearings are open frame & lubricated by engine oil. Disadvantage is that the outer bearing is set about 5 or 6mm inwards from the cam drive gear rathar than being right up against the gear. Also, I think the outer bearing may be slightly smaller than in the later cars.
    However, to the best of my knowledge, no one with an early carb'd car has reported a cam drive bearing failure on Fchat or FerrariList.
    The newer design was to put the outer bearing outside of the seal & depend on it's factory lubrication. This mounted the bearing right up against the cam drive gear. Best possible location for radial force transfer into the housing with minimal twisting moment. Believe that the bearing was somewhat larger as well. Subsequently the later QVs & 328s came with an even larger outer bearing.
    IMHO, the reason we're seeing these outer bearings fail is that the factory lubricants are drying out & breaking down after 20 years more or less.
    When doing JWise's car I talked with a tech who worked for the MA Ferrari dealership from '77 to the late '80s. Said he didn't remember them having a single timing bearing failure. Was surprised we'd run into them.
    As to 'better quality' bearings, I took the factory bearings to a local bearing supply shop. They said that the SKF bearings were SKF's top grade of bearing. BTW, bearings have constantly improved over the years. Tolerences, alloys, hardning methods, lubricants of today are significantly better than what was available in the 1970s.
    About the only practical way to utilize a 'better' bearing would be to do some significant redesign & machining to accomodate an even larger bearing, unfortunately, this would include machining the block, the timing cover, and most likely making a new shaft with it's integral gear! This seems to be what the 408 guys are doing.
    Both the NSK & SKF web sites have a lot of good technical tutorial material on bearing selection/application trade-offs, etc. I really like NSK's 'Handbook' section, especially the explanatory chapters:
    http://www.tec.nsk.com/Handbook.asp?menu=1,0,0,0&PageID=/TypesAndFeatures/IndexTypesAndFeatures.html
    Spent a lot of time researching them when my timing drive bearings went a few years ago. Decided I couldn't do better than the original bearings.
  7. ham308
    ham308 Formula Junior
    Nov 3, 2003
    358
    NE Switzerland
    Richard Ham
    My 77 308 has the earlier design with the oil seal on the outside and this failed after the previous owner had new belts fitted at a dealer.
    I did a write up (http://ferrarichat.com/forum/showthread.php?t=14913) but as the photos have gone missing I'll send you an e-mail Mark.
    As Verell says, it is possible but there is no guarantee that something won't hang up and force you to remove the engine. I was lucky and managed to do it in-situ. Personally I think it's well worth having a crack at it in the car unless you want to remove the engine for other reasons.
    Richard
  8. Gianluca
    Gianluca Formula Junior
    May 6, 2003
    349
    Centreville, Virgini
    Gianluca Chegai
    #8 Gianluca, Jan 13, 2005
    Mark,
    I wanted to do some basic service on my 81 gtsi (belts, bearings, w/p etc.) and decided to remove the engine.
    With all the help from this forum, it was an easy job and a very complete one.
    Every part of the engine was cleaned/replaced/repaired short of taking the heads off.
    I have no previous experience on the subject and a moderate collection of tools.
    Taking the engine off, may be a slightly longer job but I feel that the return/pride/knowledge return is very high.
  9. marks308GTB
    marks308GTB Karting
    Jun 6, 2004
    114
    Mark S.
    I got an email from ham308(thanks, again) with an excellent description and photos of replacing the bearings. Am in the process of deciding what to do with this.
    Have to admit that the completely cleaned up engine looks beautiful. But would still rather try to do without engine removal. Gives me plenty to think about.
    Mark
  10. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    #10 robertgarven, Jan 13, 2005
    I had a rear bank outer bearing fail. I have heard the inner ones rarely go bad? Are you sure the growling noise is coming from there. I had a chattering sound at idle and after much research and work turned out the engine was idling to low making the transfer gears chatter. The idle should be at 900-1000rpms mine was idling fine but at about 750-800 causing the noise after I increased the idle it miraculouly dissappeared!!!
  11. marks308GTB
    marks308GTB Karting
    Jun 6, 2004
    114
    Mark S.
    Idle speed is about 1000 rpm and very,very smooth.
    The grinding noise is not very audible at idle. Increases and gets much more noticeable at about 3000 rpm.
    Am aware that the inner bearings dont fail that often. Am hoping this is maybe the alternator or the AC compressor. My luck has not been that good recently, but hoping anyway. Will try to isolate the problem by running with no alt and/or with no AC compressor.
    Mark
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Gianluca,
    Pls tell us what you used to get your engine so clean.
  13. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    errr. That's just Paint Verell!!
    Painted engines tend to look good for a short while and then very scruffy soon after.
    The best method is thorough cleaning using solvents etc, and some light bead blasting on components that can be cleaned easily internally (not heads or blocks).
  14. Gianluca
    May 6, 2003
    349
    Gianluca Chegai
    Verell,
    I scrubbed down with parts cleaner and use Rub 'n Buff. Not too difficult at all.
    Ferrarifixer,
    It is not paint. Rub 'n Buff appears to be a metallic powder in a wax binder.
    A very small amount will cover a large area.
    To my surprise, it does not look scruffy at all after time goes by. Not only it retains the look but it can be refreshed by simply going over with a rag.
    Many people here have used it and they know how great the stuff is. for those who have not yet tried, do yourself a favour and buy a tube to try. You will be simply amazed.
    Any art store sells it in their picture frame department. 3-4 $ a tube.
    The tube of the stuff is very small. About 2 tubes to do every single part on your engine.
  15. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    I love Rub&Buff
    Great stuff, and cheap too.
    Don't use it on Suspension components, it is not rust proof so it appears $hitty after a while. On aluminum engine though, it is hard to beat.
