Gearbox oil to my 328 GTS? | FerrariChat
Discussion in 'Technical Q&A' started by Stefan_328, Jul 12, 2006.
  1. Stefan_328
    Stefan_328 Rookie
    Nov 2, 2004
    12
    Hello!
    I have my 328 for almost 2 years now and i am very happy.
    But i have and my 328 friends i sweden, problem whith the gearbox when it´s cold. It´s difficult to change to second gear. it gets better when it´s warm.
    I tried the shell oil that the ferrari manual say. And now i tried the Castrol XJ.
    Do you have any oil that´s works? I know that this problem is on all 328 but i hope it gets better whith better oil. I found on internet that you should drill a hole inside the gearbox to get more oil to second gear. But in that case you must take the hole gearbox apart.
    Happy driving:)
    Stefan
  2. chrisx666
    chrisx666 Formula Junior
    Dec 6, 2004
    562
    YorkshireUK
    Chris B
  3. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
  4. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    More firsthand positive experience with the Redline 75W90NS. Just put it in my 308. I hope you can get this stuff over there, because it's THE stuff to use!
  5. marco246
    marco246 Formula Junior
    Mar 25, 2004
    288
    Hawaii
    Mark
    Stefan,
    If you can't obtain Redline, try Mobil 1 75w-90. I use it in my 328 and it works fine. Using it eliminated chatter from the limited slip differential that I was getting using Shell. The Mobil 1 also enables the shift to second more easily. Some on this board have said the Mobil 1 deteriorates over time; it may. I have only about 2000 miles on the oil and it's OK so far.
    Cheers, Mark
