456 Top-end Rebuild Pics (valve guides)
Discussion in '456/550/575' started by Diablo456, Jan 15, 2007.
  1. Diablo456
    Diablo456 Karting
    Jul 27, 2006
    145
    #1 Diablo456, Jan 15, 2007
    I'm happy to report my 456 valve guide rebuild is almost finished. I had the day off, so a friend and I took the Piper Cherokee up to Denver to inspect the car. Should be finished next week; the heads are back on the car and the valves were under adjustment today. Got some nice pics of the engine and thought you might like to see some of the internals. I always enjoy seeing the interior of our engines, so here you go. As always, Ferrari of Denver appears to be doing a careful, thorough repair.
    In addition to the valve guide replacement, under the "since we're already there..." theory, I'm also replacing the engine mounts, certain hoses, full timing-belt service (idlers, bearings, seals, belt), and the steering rack is being rebuilt (slight leak).
    Hope to have a nice, tight 456 back in the garage soon. Check my older posts in this section for a full description of the initial valve guide problem and diagnosis.
  2. f40car
    f40car Karting
    Jul 25, 2006
    63
    NJ
    ZZ
    nice red carpet :)
    hope you can get the 456 soon enough for the good weather before winter comes.
  3. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    just for reference... can you say how close the stamped marks were after dialling in the correct cam timing...
  4. Kevin456MGTA
    Kevin456MGTA Rookie
    Jan 4, 2005
    7
    GAlveston, Texas
    Kevin C. Walsh
    News Flash
    Another 2000 456MGTA with Valve issues
    Slight Smoke at startup led to continuous smoke within an couple hundred miles. Then SLOW DOWN light and CHECK ENGINE.
    Car is at Ferrari of Houston now. Initial diagnosis is failure of the bronze valve guides allowing oil into engine. They even asked me to come by and check it out for my self. Seeing is believing. Now I am waiting for the BILL.
    Any Thoughts?????
  5. Diablo456
    Diablo456 Karting
    Jul 27, 2006
    145
    Ouch. Sorry to hear about this. Your symptoms were same as mine: slight smoke to crop duster in a few hundred miles. I don't suppose you had a recent compression/leakdown test? If nothing else, be interesting to post the results here.
    Regarding the bill, my valve guide replacement at FoDenver is quoted at about $11k, not including other work I'm having done, but including the belt service. All of my guides are being replaced along with the full belt service (tensioners, seals, etc.). Also note the work on my car was done with the engine in-place; let your shop know about this, as FoD initially thought the engine would have to come out for this service.
    The only slightly good news at the end of this tunnel: you won't have to worry about valve guides again, and it should help resale.
    Check my prior posts for various interior pics of the engine; might be handy with your shop to confirm diagnosis. Do be sure to have a cylinder-only leakdown test done once the heads come off (see my and Brian's prior posts for the method). I did this at Brian's suggestion to confirm my piston/rings were still tight.
  6. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    I'm curious (primarily because I'm considering buying a used 456) --- what does the factory power train warranty have to say about this? Any coverage options whatsoever? Is the car out of warranty due to mileage or age?
    The idea of spending 75K on a car and maybe another 1-2K per year, on average, for maintenance is feasible...
    But, spending 75K on a car with only 25,000 miles on it...and, then having to drop another 11-15K within the first year of ownership would really piss me off...
  7. Diablo456
    Diablo456 Karting
    Jul 27, 2006
    145
    456s are out of factory powertrain coverage (time) and still in emission warranty coverage. My inquiry on the emission warranty was greeted with "not a chance". sigh.
    It's very rare for Ferraris to reach the mileage limit on warranty coverage (but not impossible).
    +1
    BTW, if you'd like to see the car in person, it's close to you a FoD. Drop me a PM if you wish.
  8. michael bayer
    michael bayer Formula 3
    Aug 4, 2004
    1,293
    As I think this through, a compression leak down test may not uncover worn guides for some time. The engine designers work the geometry to minimize lateral valve to guide forces, so the valves will naturally "seat" and seal. I believe the guides would have to erode so badly that the valve would slide out of the seat - thus minimal warning before failure. Comments?
  9. Rifledriver
    37,104
    With 6mm valve stems and the very narrow seats used on a valve of that small a diameter very little wear is required for compression loss.
  10. finnerty
    May 18, 2004
    10,406
    Yes, this is really the problem. It's very hard to detect worn valve guides early on many engines --- unless, you pull a camshaft, remove the tappets, and use an indicator to check lateral play on the valve stems, and this certainly could not be a practical part of any PPI. By the time there is enough stem-to-guide wear to cause valve seating problems (which will show up on compression and leakdown checks), it's usually too late. As Rifledriver points out, the geometry of these valves and seats is very sensitive to slop in the stem.
    Even if Ferrari has said that this is not their responsibility, I'd be saving all my receipts and paperwork for this repair work --- have the shop document everything very thoroughly, complete with photos.
    My guess is this problem will be showing up more as more 456's get some miles on them. And, unless Ferrari can prove that all these cars have been abused or serviced incorrectly, they have no leg to stand on.
    It's unacceptable for this to be occurring on any engine with that low of mileage --- period. And, it is Ferrari's fault ---- either they have a design flaw or they are allowing discrepant components from their suppliers to get into their manufacturing system (and be accepted). It doesn't matter if the defective parts came from a supplier, Ferrari owns the design and the QA management of their supply base. If they (Ferrari) assert that a supplier gave false / misleading info so that parts were believed to be okay, and they wish to collect damages from a supplier after they (Ferrari ) pay out to their customers, that's their business.
    If it were my car, I'd wait until after enough of these failures are documented, then I'd find a good Product Liability attorney to make Ferrari cough up a settlement. No warranty allows any manufacturer --- not even Ferrari --- to avoid responsibility from something this drastic.
  11. opus10583
    opus10583 Formula 3
    Dec 3, 2003
    1,779
    Westchester, NY
    Mark
    How is wontonly burning motor oil NOT an emissions issue?
  12. finnerty
    May 18, 2004
    10,406
    Indeed...seems as though a clever / aggressive lawyer might be able to make a loophole out of this...
    Precedent has already been set with the 2-valve, injected 308's and the 355's (exhaust manifolds).
  13. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    I don't know US law at all... but I would imagine it IS an emissions issue...
    but it's the warranty thats under scruitny...
    liability is the issue, not the emmision problem.
    Cars wear out, it's what they do.
  14. finnerty
    May 18, 2004
    10,406
    If someone wants to pursue this, it wouldn't hurt to give the EPA a call --- I'm sure they can say whether or not it should be treated as an emissions compliance failure.
    Funny, but if this was happening on late model Ford's, the factory would probably rush to be proactive --- doing a recall, offering reimbursement, etc. --- just to protect their image and market place position. But, since Ferrari has no real competition, I imagine they don't feel the need to be too forthcoming.
  15. finnerty
    May 18, 2004
    10,406
    DIABLO456 ---
    Thanks for the offer to go have a direct look at your car. Frankly, I'm afraid that if I did, it would scare me too much, and I wouldn't be able to bring myself to buy a 456!!! LOL
    Actually, I moved recently and am no longer residing in the Denver / Boulder area...
    Incidentally, don't forget about Dave Helms at Scuderia Rampante in Boulder should you ever feel you want a change / second opinion from FoD.
    Nothing against FoD, just an enthusiastic recommendation for Dave!!!
  16. PassionIsFerrari
    PassionIsFerrari Formula 3
    Aug 15, 2004
    2,454
    out of curiousity, what are those 2 gauges used for??
  17. Diablo456
    Diablo456 Karting
    Jul 27, 2006
    145
    Great recommendaion. In fact, I had a long discussion with Dave about my car, and he went a step further and advised the machinist in Denver who did the actual guide removal/replacement on my heads. Dave is an incredible asset and highly recommended. BTW, Dave repaired my 88 TR back in 1999 when it had a cat fire; nothing but praise for Dave from me.
    In my case - given that the car is potentially covered under the emission warranty - I felt it best (as did Dave) that an official Ferrari dealer perform the 456 valve guide repair.
  18. Rifledriver
    37,104
    Cam timing.
  19. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    Diablo 456,
    glad to see some progress with your car, but what is taking them so long?
  20. Diablo456
    Diablo456 Karting
    Jul 27, 2006
    145
    Snow = 3 week delay. They outsourced the machining job, and I had Dave Helms consult for this as well. The heads came back from the machinist 15 days ago.
    Last delay is a rebuild of the steering rack (it had a slight leak). Initially, they wanted to replace the rack, for about $3.5k, but we located a California shop that could do the rebuild for $600, so we're waiting for the rack to come back which will complete the repair.
    No hurry, snowy where I live and the car will just wait for better spring weather.
  21. Fritz Ficke
    Fritz Ficke Formula 3
    2,266
    Tucson, AZ.
    Fritz Ficke
    on the emissions issue, burning oil does not produce the gases checked for by EPA standards one of which, C02 is tastless colorless and odorless, Diesel engines do not make the same gases that gasoline engines so the EPA check on Diesels is just how thick the smoke is, Intell the Diesel/Ferrari engine fails to the point of poor combustion that the computer can not correct for it will get a clean bill of health by EPA standards even while belching lots visable smoke.
  22. Rifledriver
    37,104
    Oil smoke most certainly produces HC, which along with CO is one of the top 2 gasses tested for. A car burning much oil will fail. Of the other gasses, O2, and CO2, will be negatively impacted by the high levels of HC.
  23. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    They are not pressure gauges for hoses, but I believe they are dial indicators to help determine phasing of the engine by indicating piston position.
    On the other hand, I could be wrong...
  24. Rifledriver
    37,104
    See post 18.
  25. finnerty
    May 18, 2004
    10,406
    What about damage to the cats after having all this oil passed through them? Wouldn't they also need to be replaced?
