355 295/35-18 TIRES | FerrariChat
355 295/35-18 TIRES
Discussion in 'Technical Q&A' started by jratcliff, Oct 14, 2004.
  1. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    Ok so will the 295/35-18 Michelins fit using a stock rim without rubbing anywhere on a 355 Spider? Need to order some new tire and want to up size if and only if I have no problems with clearance.
  2. richard_wallace
    richard_wallace Formula 3
    Feb 6, 2004
    1,957
    Cincinnati, Ohio
    Richard Wallace
    You can run 295/35's on the rears without increasing rim size. However you will need to lower the rear springs by a turn or so. Here is some great info on what you will want to look for in doing this... You will notice - I was going down the same road as you a few months back :)
    http://ferrarichat.com/forum/showthread.php?t=13258&highlight=355+tires
    http://ferrarichat.com/forum/showthread.php?t=16071&highlight=355+tires
    http://ferrarichat.com/forum/showthread.php?t=6187&highlight=355+tires
    If you do a search on 355 tires - you will find much more information if these three do not answer your questions.
    Thanks,
    Rich
  3. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    Thanks Rich for the info.
  4. Europeanroadandracing
    Europeanroadandracing South Carolina
    Dec 19, 2003
    2,228
    Isle of Palms, SC
    Karl Troy
    You don't need to change anything. The sidewall on the 295s is only 2.75 mm
    shorter than on the 265s. You will never see or know the difference. Put them on and forget about it.
    Karl
    www.europeanroadandracing.com
  5. 95spiderman
    95spiderman F1 World Champ
    17,433
    ny
    i have that size on 10 rims on my 348 spider. fits perfect so youll be ok also
  6. Europeanroadandracing
    Dec 19, 2003
    2,228
    Isle of Palms, SC
    Karl Troy
    If you want to get technical you would actually have to raise the rear slightly to compensate for the shorter sidewall but as I said unless you are into competition driving you will never feel the difference.
    Karl
