355 tires | FerrariChat
355 tires
Discussion in 'Technical Q&A' started by beezerhound69, Apr 26, 2004.
  1. beezerhound69
    beezerhound69 Karting
    Feb 3, 2004
    136
    Suwanee
    Tom
    Hi there..Goodyear Firoano's that came original are done in the rear. The good folks at a performance tire shop here in Atlanta say they were mediocre, at best. Recommending either Bridgestone S01's or a BF Goodrich KB..Michelin is behind the new KB's with their purchase of Bridgestone...Any other recommendations?
  2. richard_wallace
    richard_wallace Formula 3
    Feb 6, 2004
    1,957
    Cincinnati, Ohio
    Richard Wallace
    I just put (on Saturday) Kumho Escta's 275/40's on my rears... Pretty decent tire and at 229 each - not bad...
    There is a huge thread on this from last week - on sizes, etc. Do a quick search...
    I was going to but the BF 295 35 - Which fit and have the right ratio as the 265 40 originals - but they are running at 300+ and didn't seem to have much advantage for the cost.
    You will either have to go 275 40 or the 295 35 - It is difficult to find the 265 40's any more... If you go with the 275 40's - put about 1 extra PSI (37 psi instead of 36 - which makes it the same rolling dia as the 265 or close.
    Rich
  3. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,728
    I agree with the above except:
    The designation is 275/40ZR18 not 275 40
    You should subtract 1-2 PSI not add.
    If you go with 295/35ZR18 you will want to lower the rear by 2 turns of the shock collar to offset the wider rear tires understeer augmentation.
  4. richard_wallace
    Feb 6, 2004
    1,957
    Cincinnati, Ohio
    Richard Wallace
    Mitch - You are awesome BTW... And correct...
    I will be going out and letting 1 - 2 lbs out of my tires now... Darn it... :)
  5. beezerhound69
    Feb 3, 2004
    136
    Suwanee
    Tom
  6. Mitch Alsup
    Nov 4, 2003
    9,728
    OOPS::make that raise the rear by 2 turns on the shock collars.
    <<me bad>>
