348 Gearbox Problems | FerrariChat
Discussion in '348/355' started by Kevinbag, Mar 1, 2008.
  1. Kevinbag
    Kevinbag Karting
    Apr 6, 2007
    57
    Cape Town
    Kevin
    I hope you guys can advise me. I have a 1990 348 TS. I have noticed that whining has started using all gears. I hear it at low revs. I have also noticed that the gear level is "Knocking" and moving in 5th gear. When I change it into 5th and push the throttle pedal, the gearlever moves forward a bit and makes a clicking noise. When I get off the throttle, the gear lever noticably moves backwards a bit and forward again when I push the throttle. This happens all the time in 5th gear only.
  2. plugzit
    plugzit F1 Veteran
    7,779
    Redondo Beach, CA
    Bruce Bogart
    Time to drain it and look for metal. Now.
  3. Ricambi America
    Sponsor Owner
    Stop stop stop driving ASAP. Mine turned itself into a food processor last fall. Not cheap... and I have an "in" with the parts. :(
  4. group77racing
    group77racing Formula Junior
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    How many Km's on the odometer? Out of curiosity. thanks
  5. Kevinbag
    Kevinbag Karting
    Apr 6, 2007
    57
    Cape Town
    Kevin
    64000 km, thats about 40000 miles. I think I am going to crawl to the local Ferrari agent on Monday morning. What do you think is causing it?
  6. Ricambi America
    Sponsor Owner
    Par for the course. Mine was 46k when it blew.
  7. Seymour-Vadge
    Seymour-Vadge Rookie
    Feb 10, 2008
    18
    Co-incidentally I have a very similar problem and just thinking out loud, assuming that I 'might' have a perfect F355 6 Speed Gear box in the garage, would it be a relatively straight forward transplant? Or would it also require major modifications being done elsewhere.
    Thanks SV.
  8. Ricambi America
    Sponsor Owner
    It can be done. It has been done. It's not as simple as some fchatters might have you believe. Contact Paul Hill (Hill Engineering) directly for the details. Some one-off brackets and such are needed. The coachwork, rod assembly, lever, etc are also a bit expensive. In the end however, it sure beats the crap-box that Ferrari tossed onto our 348's.
    http://www.ferrarichat.com/forum/member.php?u=101
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    It would take less effort to rebuild the old 348 gearbox, typically. The 355's 6 speed tranny will work in a 348, but the alternator may have to move to the other side of the engine, and you have to install rods and a different gearshift-box mechanism (348's are cable-shifted, 355's are rod shifted).
  10. group77racing
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    And this whole time I thought 355 rods were behind the wheel...
  11. Seymour-Vadge
    Feb 10, 2008
    18
    Hmm, thanks guys. I think I'll have a chat will Paul Hill before I start getting excited. I suppose anything is possible, although I don't really want to have to start getting custom bits made otherwise it just makes future repairs/maintenance a pain in the ass.
  12. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,451
    On the Limit
    Dino
    Over the last 18 years, my 348 box has blown up 2X. The second time we rebuilt the box using stronger 355 components in place of the weaker 348 ones. I don't suspect that there will be any further implosions!
  13. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    I've always wanted a 348 but your experience with the gearbox and bent valves really puts me off. And... you strike me as the kind of person that did his homework before buying the car you did, someone that doesn't skip maintenance and doesn't abuse their car.
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Here's an interesting thread where Reinerkaiser drove his 348 until he heard the gear whine...stopped almost immediately...and was able to repair the transmission problem for a few hundred Dollars (?) as the damage was not significant apart from replacing two bearings and properly torquing/pinging/loctiting two locknuts (which seem to be the self-same root cause of the 348 gear boxes that do blow up): http://www.ferrarichat.com/forum/showthread.php?p=136859703#post136859703
  15. Ricambi America
    Sponsor Owner
    I think you have rods confused with nuts. :) Plenty of those behind the wheel too.
  16. Kevinbag
    Kevinbag Karting
    Apr 6, 2007
    57
    Cape Town
    Kevin
    Tomorrow morning I am taking the car, very slowly, in the our ferrari agent here, who is very competent. As soon as I have any info I will be around there with camera and will keep you all informed.
    I must tell you guys in the USA that you are fortunate to have these cars sort of easily available and very "cheap". Over here a 348 will cost about $ 115 000 US a 355 about $ 170 000 US and a 430 (if you can get one) $ 360 000 US.
  17. Ricambi America
    Sponsor Owner
    Kevin, with the greatest of respect, I implore you to TOW the car, do not drive it. The extra $500 (or whatever) flatbed bill is nothing compared to the damage which could occur if things really go "bump". Moreover, if the box is already cooked, a few extra hundred dollars (or thousand ZAR in your case) is a drop in the bucket. Please, my friend, don't drive it.
  18. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    +1 Don't drive it, get it towed.
  19. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    After looking at photos from Daniel's train wreck, I would say "Excellent Advice" ,,, you really should tow it...
    Mike in Kuwait
  20. F512M
    F512M Formula Junior
    Dec 9, 2003
    504
    Houston, TX
    Jeremy Lawrence
    Add one more to the list.... Do not drive the car. Do the right thing and have it towed.
  21. Kevinbag
    Kevinbag Karting
    Apr 6, 2007
    57
    Cape Town
    Kevin
    Thanks guys, I will follow your advice.
  22. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Ouch!! You guys pay top dollar for Ferraris also!!! :(:(
  23. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    14,635
    Juan
    Did the replacement parts go up since Ferrari UK now has controll?
  24. F512M
    Dec 9, 2003
    504
    Houston, TX
    Jeremy Lawrence
    What does it cost to ship a 348 to South Africa? Mine is for sale tomorrow at $115,000... LOL :)
  25. wingfeather
    wingfeather F1 Rookie
    Feb 1, 2007
    3,653
    rock bottom
    Same here! You'd think the 348 would sell for more in the USA - especially the Spider (considering the production numbers).
