348 gear box noise | FerrariChat
348 gear box noise
Discussion in '348/355' started by rddvl, Jan 18, 2008.
  1. rddvl
    rddvl Rookie
    Jan 14, 2008
    38
    New Zealand
    Any body out there have a gear box issue in a 348? Mine is currently with the dealers having the box dismantled, it started making a whining noise in 4th and 5th gears, still functioned normally though but i have heard horror stories of these boxes practically disintergrating with little or no warning so am getting it sorted, am seriously not looking forward to bill. Wife would like me to sell the car yeah good one.
  2. Ricambi America
    Sponsor Owner
    Mine blew up with the exact same situation in September. The g'box was, for the most part, destroyed. Don't know where you are located... if you are on the east coast, I STRONGLY encourage you to contact "Competizione & Sports Cars" in Gaithersburg, MD (301-977-9484)
    Mine started with the whining in 4/5 also. 1990 348ts. Rather than rebuild mine, I actually purchased a brand new, in the wooden shipping crate, "sealed in 1994" new transmission. It was, to the best of my knowledge, the last known complete never-touched, 'at the factory' tranny left on earth. I paid a lot.... but I can easily say, fixing a broken one with trained technicians and real parts would have cost more.
    Whatever you do, STOP DRIVING. It only gets worse and more expensive.
  3. rddvl
    rddvl Rookie
    Jan 14, 2008
    38
    New Zealand
    Thanks Jack Russell Racing, I think I contacted you about a month ago regarding this problem/trying to locate a new gear box( if you are the person from Ricambi), well I could'nt find a new one anywhere but did locate a couple of boxes from wrecked cars and one rebuilt by factory. Have decided to get mine rebuilt better the devil you know. Car is located in New-Zealand. Mine also 1990 ts model, had it 5 years first major problem apart from master clutch cylinder failure.
  4. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    My gearbox is fine knock on wood, but how much does it cost to rebuild a 348 gearbox? are we talking 4 or 5 digits in the price? Got to start saving if its 5 just in case ;)
  5. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Any suckers, errrrr I mean, anyone wanna take bets it's that damn oil pump bearing again? :D :p
  6. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    At a bare minimum you are looking at the mid 4 figure price range, and that is if you are doing the work yourself. Mine blew up and I rebuilt it with the help of my buddies fatbillybob and Plugzit. If it happens again I'm putting in a 6 speed from a 355. The thing that cause these stupid thing to grenade is the ring nut coming loose, on the gear box oil pump side, of the main shaft. Then the bearing starts moving around, and then the bearing cage goes kablamo.
  7. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    What's cheaper?
    Rebuilding a 348 gearbox or selling an existing one and installing a 355 gearbox?
  8. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    I'm wondering if doing a "major" on the gearbox to check this out might not be a bad idea as preventative maintenance. This issue seems to be popping up more frequently as our cars age.
  9. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Yeah you could, but you'll have to disconnect the gear box from the back of the engine to get to the side cover.
  10. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    I think I've seen a thread here with pics of 348 transaxle spline failures, but not sure if that's a result of the ring nut loosening. One of my previous neighbors has owned his 348 for over 17yrs (I guess since new), and his transaxle failed twice. However, his has upgrades for track, and he previously tracked it a lot, I understand. The second time, he upgraded his transaxle with 355 parts/spline parts, and he says that solved the problem.
    I guess I'd like to confirm what 355 parts that 348 owners have used when overhauling their transaxles.
  11. ckracing
    ckracing Formula Junior
    May 20, 2006
    728
    Jacksonville,Florida
    Charles
    The problem is ring nut coming loose, on the gear box oil pump side, of the main shaft. Then the bearing starts moving around, and then the bearing cage goes kablamo.
    I hear this is a problem. Can you get to the oil pump Nut without taking the gearbox a part?
    If you can, can the Nut be tacked welded to keep it in place?
    Just asking
  12. fatbillybob
    Aug 10, 2002
    29,026
    socal
    Ahem.....HOGWASH! The 348 gearbox is basically bullitproof. I proved it. I race it on full slicks and run it harder than any of you. The deal with 348 gearboxes is assembly. If assembled right they do not come apart. I hate to say it but I do not think Daniel's "new" box is any better than any other exisiting box if Ferrari built it the same way as all the others = sloppy! I think I can actually say I have rebuilt more of these boxes than anyone including most pros. There are some pros on this list who have way more experience on 348 boxes like the very respected Dave Helms and there are several quotes on Fchat of his belief that the 348 box is pretty tough too. So sure there are issues with a minority of 348 boxes but it is not the box it is the assembly. In my own case Ferrari did not "stake" a lockring can you believe that? Too much wine at lunch! Ferrari is responsible for the problems these cars have. Once sorted by non-ferrari doctrine these cars can turn into daily drivers.
  13. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    So since I plan to soon do a major on my new (to me) 348TS, can you provide specific advice/steps on what to check and verify/tighten, etc. and how to go about it, while the engine is out? Or post links that apply? Thanks.
    Rick
  14. rddvl
    rddvl Rookie
    Jan 14, 2008
    38
    New Zealand
    I will let you all know what exactly was wrong and how much it costs to fix when completed. I wonder if I should go down the road of replacing with 355 parts??
  15. fatbillybob
    Aug 10, 2002
    29,026
    socal
    I think a good box will not come appart or need paranoid servicing. I would drive my car often and really get to know the car. If you hear or feel and unusual gearbox noises stop driving it and inspect it carefully. Damage comes when the warning signs of noise and grinding are ignored because the box will still shift. A good box will stay good for a very long time. I am so skeptical of Ferrari's ability to pay attention to detail that given the choice between Daniel's new box and my old rebuilt box with a trackrecord of staying together...I take my box over his new but unknown box. Only time will tell if his new box stays together. Ferrari is awesome at what they do. Often however they fail to do it consistently well. We see this with gearboxes, 355headers, 456 head rests, sticky interior parts etc,....
  16. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    I think that the consensus is not a part deficiency that needs an update (like being replaced with a 355 part), but that the ring nut just needs to be properly staked during assembly or re-assembly.
    That being said, the gearbox failures *seem* to be hitting the earlier 348's instead of the 93's, 94's, and 1995's...though perhaps I just haven't seen enough data to know otherwise. It's by no means certain that the later model 348's are safe.
  17. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Keep in mind that the 355 tranny isn't plug-n-play into the 348. The 355 has the alternator on the opposite side of the car to allow for clearance...and the 355 uses rods instead of cables for the shifts...so some additional changes must be made to accomodate.
    Very doable, but you'll have to get dirty to pull off a quality 6 speed upgrade.
  18. fatbillybob
    Aug 10, 2002
    29,026
    socal
    Yeah....Andy never did show us pictures of his homemade linkage. Inquiring minds would like to see....
  19. chris_gilmartin
    chris_gilmartin Karting
    Jun 5, 2004
    110
    My 1994 GTC had a gearbox failure, so it's not just the early cars. The guys who fixed it reckoned that it wasn't set up properly from the factory, and that this seems to be the case with almost every 348 gearbox issue they've seen.
    CG
  20. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    14,640
    Juan
    A dealership just had my gear box off the first of 07, said I would have problems in the future. Best we can tell, no locktite on the ringnut, and not pinged properly. They said they tightened the ring nut. However, that appears to be what caused the failure as the ringmut came loose. My friend said you could take it off with no assistance as it was very loose. He rebuilt it saving me thousands, and thanks to lots of folks on this board like FatBillieBob, it is back together. Super tightened, super pinged, and my straight exhaust features a beautiful black paint job.
    Oh yeah, the parts where stupidly priced, like 480 for a bearing that was about 180 before Ferrari UK got exclusive listing from the factory, and I have been told there will be another price increase. No gears had to be replaced, only spacers, bearings, etc.
  21. Organiser
    Organiser Formula Junior
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    My 94 Spider has around 111,000 km on it now, the gearbox is fine but as its out with engine for a cam belt change and flywheel regrease I will be having the ringnut checked for tightness. Knowing my luck it would come loose after it was put back in the car, much better and cheaper to do it now!!
    I was talking to a 355 Challenge owner on Saturday, his car is in for a cambelt change right now and the tech found a loose nut in his gearbox and he was told it was not the the normal one that comes loose, so it seems that 355`s have a similar problem??
    Regards,
    Phil.
  22. jqpd99
    jqpd99 Formula 3
    2,484
    Ottawa
    DFO
    Hi All,
    I currently have the gearbox off the car and although I haven't had any issues with the gearbox, if it's possible, I would like to at least see if the ring nut is loose. Can someone point out this ring nut in a diagram and let me know if it's accessible without opening the gearbox itself.
    JQP
  23. rddvl
    rddvl Rookie
    Jan 14, 2008
    38
    New Zealand
    Help, (regarding 348 gear box noise) gear box is being pulled to bits and so far it needs a new crown wheel set , not to mention bearings. Can somebody please tell me what a crown wheel set is? does anybody no of a good gear box for sale
  24. fatbillybob
    Aug 10, 2002
    29,026
    socal
    Do you want a stooge rebuild? If you supply beer and pizza I bet I can get the guys to help. Or where do you live ? If it is Hawaii you can fly us all out and we'll rebuild it in your garage.
  25. TheOnlyest
    TheOnlyest Formula 3
    Sep 25, 2007
    1,686
    Las Vegas Nevada, US
    Steve
    You cant possibly be serious!?!
    Would you and ''the guys'' do my major for pizza, beer and a trip to Vegas??
